Noise in valve cover!!!!
blown331stang
Pennsylvania
Hello, I have a 93 3.2 liter. It was running fine until now, I hear a noise coming from the upper part of the motor I think its from the valve covers, can it be a worn cam or rocker arm adjustment? It does not sound like bearings. Please help or im gona sell ot or junk it :fit:
Could be timing belt tensioner. There are no rockers and I've never heard of a "worn cam" making noise.
riden2low
Portland, Oregon
Most likely the timing belt tensioner. Go to Northern Tools or some place like that and pick up a stethoscope and start listening. I thought I had the same problem, noise coming from the rear valve cover, some where around piston #1. I put the probe down close to the tensioner area and the noise was loud and clear. Got a used one from one of the guys here on the site and it has stopped.
jonheese
Used-To-Know-It-All
Fogelsville, PA
It could also be one or both of the timing chain tensioners in the head failing, depending on where the noise is.
whiteguy3
Scott MacIntire
Silver Spring, MD
If it is your timing belt tensioner I modify blown tensioner's to work as manual tensioner's instead of the stock hydrolic one's that tend to fail. PM me if you are interested.
My guess is timing belt tensioner, but it all depends on how harsh the noise is and where it seems like it is coming from. Run the car with the upper timing cover removed or just take it off and check for timing belt slack.
jonheese
Used-To-Know-It-All
Fogelsville, PA
I believe you mean the turbo encabulator.
And that's just ridiculous... Everyone knows only Chryslers have those:
[YOUTUBE]MXW0bx_Ooq4[/YOUTUBE]
That's right. I was thinking of the retro-encabulator. It's the universal one that honeywell made for everyones benefit.
jonheese
Used-To-Know-It-All
Fogelsville, PA
Yeah, the panametric reciprocation dingle-arm in those reduces the sinusoidal depleneration of the malleable logarithmic casing a lot more effectively, IMO.
HotRodKid
mmmmm ... turbo
Western NY
lol, that chrysler video is one of the greatest things ever, esp the troubleshooting part.
edit: hahaha just caught the "songbook" part, never noticed that before
LOUDSHO92
Rancho Cucamonga, CA
It is more like a tapping noise. I never heard rockers sound like that though.
It's a dual over head cam motor. If it is more of a tapping then the valves might need to be adjusted unless one has been ejected.
If it is coming from the driver side of the motor then the chain tensioner is bad.
If you want to go for the valves, we have shim kits here: SHO Source
