ViPER1313
Might sound weird but I had a crazy knock coming from the valve covers / engine valley that I thought was a bad timing chain tensioner / bad fuel injector / sticking valve or badly worn valve shim. It was very intermittent, and normally only occurred at a warm idle. It would (usually) go away when revving the motor. After checking or replacing every one of the above items, I found out that it was a bad coil pack. I never knew that spark knock could be that loud, but whatever had failed inside the coil was causing severe pre-ignition (or something along those lines) that was making the motor sound like a diesel / it had thrown a valve shim.
Just thought I would share....
