Navigation System Cheat Codes? hidden menus?
Unknown_Driver
V6TwinTurboAWD
Ontario Suburbs
does anyone know if we have hidden menus we can access in the optional navigation system?
my RX-8 had the factory navigation option and i could get into an electrical diagnostic menu which had many many many different sections... just by going into the information page then clicking up up down down up up down down
i was able to tell my speed from the GPS check how many satellites i was connected to and their position over the earth etc.
EDIT: IF YOU CAME HERE FOR THE CODES go to this thread http://www.shoforum.com/showthread.php?p=1287041
NOTE:
If the Audio Control Module (ACM) is inoperable the ACM part number may be obtained from a label affixed to the chassis.
1. Turn the ACM on.
2. Operate the audio system in radio tuner (AM/FM) mode.
3. Press and hold preset buttons 3 and 6 for 3 seconds until the speaker walk test begins.
• The display indicates each speaker as it is tested.
4. NOTE:
If the speaker walk test is the only test required, this procedure can be stopped after Step 3 by turning the ACM off.
Before the speaker walk test is complete, carry out any of the following actions:
SHO U UP
SHO Guru
Virginia Beach, VA
How about this one?? right, left, down, up, A, B, Start....Lets see if you guys recognize this one. Or how about A, B, B, A. :nut:
rbruso
unlikely
Tucson, AZ
According to gamefaqs, that for the sound check at the end of bad dudes.
A, B, B, A is the cheat code for this:
[youtube]<object width="480" height="385"><param name="movie" value="http://www.youtube.com/v/xFrGuyw1V8s&amp;hl=en_US&amp;fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/xFrGuyw1V8s&amp;hl=en_US&amp;fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>[/youtube]
walk through walls.
Keep em comin...
John Carmack is the pioneer of all FPS greatness.
