Unknown_Driver
V6TwinTurboAWD
does anyone know if we have hidden menus we can access in the optional navigation system?
my RX-8 had the factory navigation option and i could get into an electrical diagnostic menu which had many many many different sections... just by going into the information page then clicking up up down down up up down down
i was able to tell my speed from the GPS check how many satellites i was connected to and their position over the earth etc.
EDIT: IF YOU CAME HERE FOR THE CODES go to this thread http://www.shoforum.com/showthread.php?p=1287041
NOTE:
If the Audio Control Module (ACM) is inoperable the ACM part number may be obtained from a label affixed to the chassis.
1. Turn the ACM on.
2. Operate the audio system in radio tuner (AM/FM) mode.
3. Press and hold preset buttons 3 and 6 for 3 seconds until the speaker walk test begins.
• The display indicates each speaker as it is tested.
4. NOTE:
If the speaker walk test is the only test required, this procedure can be stopped after Step 3 by turning the ACM off.
Before the speaker walk test is complete, carry out any of the following actions:
NOTE:
1. Turn the ACM on.
4. NOTE:
Not Abba rbruso.
