##need help##
SHOCarGo
SHOCarGO
Utah
today i was driving on the freeway in the rain/snow when the car in front of me hit the brakes and i had no chose so i did the same. now i know not to slam on my brakes and I DIDN'T.
but for some reason the peddle got real stiffed locked up the brakes(heard the ABS Working) and throw it out of gear. i couldn't even put it in gear the only way it would go into gear is if the car was off and then when i go to start it it would throw it out of gear again.
reminder i am on the freeway with visibility only 100 feet or so. i was a sitting duck.
i got the car home now. and still trying to figure what the **** is wrong with it
please help SHOCarGo
walser
new ulm MN
so you cannot put it in any gear until you shut it off then it will go intot he gears?
NotSoSlowSHO
Gas is $$ WALK!
Moscow, IDASHO!
Hows the font end alignment feel? Is the steering wheel crooked at all?
It sounds to me like the entire subframe shifted, and now the rod shifter is out of alignment.
Thats probably the "best" scenario I can give you at this point.
The other ones are considerably worse.
SHOCarGo
SHOCarGO
Utah
went out there today to start it and its just fine.. now but a little harder to get in gear now but now it goes into gear when it running ... my question is what the **** wrong with my car
SHOCarGo
SHOCarGO
Utah
yes i 99.8% sure not its not and not 100% because i didn't get the car new i don't know if it bent to begin with or not( i have seen some crazy rod shifters) and even if it was bent before it sift OK kinda hard to get into gear
Art5
white plains, NY
maybe something is wrong with motor mount or something like that?Bolt could have broken off or something.Check rear mount
SHOCarGo
SHOCarGO
Utah
checked the sub frame and the bolts for the sub frame and the motor mounts but so far everything is ok
Art5
white plains, NY
when you drove car before all this problem, did you feel like it was hard to put it into gear or something like that?
SHOCarGo
SHOCarGO
Utah
well it hard to explane it was kinda hard to put into gear like it had no fluid. so i changed the fluid with different type then it was better. still kinda hard but i was OK with it. then after this happened(the whole freeway thing) it's like theirs dirt in there( not like the noise but the fill, when i shift, kinda like rubbing sand in between your hands. if anyone understands) ..........
went out there today, and tried to drive it now i can get into to gear but hard. seams to be better then the other day. its like it is fixing it self ..... still don't know what the **** going on
ckinney89sho
fo SHO
NY
take your tranny out and check the PP! i bet you broke some fingers on it. as for it poppin out of gear is it cable? if so check inside your shifter councel and see how the conectors are. if its rod check bushings and everywhere they connect
AREA 91
Area 91
I'm gonna guess it's a clutch/tranny problem.
Remove your starter and check the pressure plate straps.
While you are under there removing the starter, disconnect the rod shifter and stick a small screwdriver in the hole on the shift shaft. Make sure it goes into all the gears by moving the shift shaft.
Worst case scenario is that when you hit the brakes, the two front tires were rotating at different speeds (yes they will slide a bit when anti-locs kick in) causing the diff to work really hard, dislodging a diff pin. It could be settling back into it's spot, that's why it's seemingly fixing itself.
My logic might be suspect, though. I'm not sure if a loose dif pin will cause it to be hard to get into gear.
You might want to consider removing the axles and having a look to see if the diff pins are where they should be.
