Another idle issue....
jayhoyt28
93 SHO ATX
Kansas
Ok so as I said in the "cold Start Issue" Thread it has problems with cold starts. As in right when it starts ti will rev to 2 and then die. And it will do this at least 3 times before clearing up. It will be getting a new idle air valve on monday and hopefully that soves that problem and now this one as well....When I accelerate, as soon as it gets just a bit above 2 it stays there. Even when I let off the gas. Makes stopping a bit tough sometimes. Even when I do get it stopped its still revving at a bit above 2. Now when it does this I found that if I shift into neutral then back to drive it frees up and runs normal. Anyone think this is caused by the idle air valve? I hope so but if not I could use the ideas. 93 ATX
jmpSHO
Massachusetts
I hope this helps but I have a 98 Explorer that had the excact same symtoms and after I changed the IAC it went away. By the way stay away from Auto Zone IACs the first two didn't work right, I have had the third one in there for about 6 months now though.
jayhoyt28
93 SHO ATX
Kansas
Yes that does help. And its good news. I buy nothing from Autozone because I have also had problems with their parts. As with this new IAC most everything comes from O'reilly. Thank you for the quick reply.
jayhoyt28
93 SHO ATX
Kansas
Just an update...replaced the IAC and after doing the idle reset the car runs great. Thanks for all the help.
