flywheel
ckinney89sho
fo SHO
NY
ok so im doing my clutch got the tranny out and i was about to put in the new pp but the bolt patterns are differenty. are there two different flywheels that have different bolt patterns? please help this is my dd and i need it fast.
Phoenix
SHOHOLIC
QC , Canada
The very early ones have the 9.25" instead of the current 9.75" , either the flywheel or the PP of the smaller size are harder to find.
You most likely need a flywheel. Or find the smaller clutch kit , but good luck for this one.
ckinney89sho
fo SHO
NY
the bolt pattern on the two PP's are different. the disk that was on there is 9.75" O.D. the new one is 9.25" and i believe that they are both stamped steel. a magnet sticks to both
Phoenix
SHOHOLIC
QC , Canada
Ohhh the new one is 9.25? , Where did you buy this? I hope you didnt get screwed...Cause its actually worth less then the standard one.
ckinney89sho
fo SHO
NY
my car is tore apart and its my dd. i guess i was ignorant that there was more than one clutch and flywheel for this car so i just bought it thinkn it was right. if i had hair ide pull it out!!!!
ckinney89sho
fo SHO
NY
so what do i need to get? the flywheel to fit the clutch i got(if possible) or a new clutch?
FastAndFurious
Washington
You could just resurface your old flywheel(9.75 one) if it's in good condition. I recommend you get a 9.75 flywheel rather than buying a new clutch for 9.25 flywheel.
FastAndFurious
Washington
where can i get a cheeeaaap one! im already out $150
The cheapest one I can find is like 215 bucks on ebay.. You could try to sell the clutch kit you have on ebay. Or post it on wanted section. Some sho onwers might have new clutch kit that they can sell to you.
Phoenix
SHOHOLIC
QC , Canada
ebay or rockauto or shosource , and maybe your local parts stores if you need it now....I doupt you will find one under 189$
I can send you a 9.25 flywheel if you want it. It will need to be resurfaced. Shoot me your address and I'll get a shipping quote. It can be there by tuesday if you are in the western part of NY.
By the way James, the engine in the car you sold Beth had the original flywheel and clutch...148,000 miles and it was still working.
ckinney89sho
fo SHO
NY
damn, i just bought a 9.75 kit at auto zone for $240. if it dont work out ill definately hit you up for that. i didnt want to spend that because its my nephews bday party saturday and now i cant afford him.
LOUDSHO92
Rancho Cucamonga, CA
There's a reason Ford recalled it, because it is a weak setup and wont last long. I would never go for the 9.25 setup.
thatSHOguy101
