Finally putting my engine together
egroce11
Taylorsville, Ut.
:woo-hoo: I got the block from the machine shop thursday. The heads have been done for awhile and on the shelf. Spent yesterday and today getting parts recleaned and everything ready to put it together. I'll start doing that in the A.M.
I took some pictures and will take more as I work on it. It feels great to be doing this.
Ernie
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
:) Been there, done that! Like a kid the night before christmas. I bet your up at 6am in the garage ready to go. We'll be here for moral support if needed tommorow... well, I probally will be anyway.. :)
CademiaX
What's an SHO?
Utah
I gotta come check it out :)
If you are still working on it after 5 on the weekdays give me a call!
(pm'd you my number)
firebat45
Edmonton
This going to be another performance build or are you rebuilding it to stock specs? Let's see some pics!
egroce11
Taylorsville, Ut.
Performance build with just about the same specs as the last one.
Did figure we might have been down on a little power due to pre det in the firing.
firebat45
Edmonton
Ah, in that case, subscribed! Your engines are some of the most interesting SHO engines, to me at least.
mattsho1993
SHO owner
albion, new york
what did you do to the block curious? and also anyone ever shave heads or aynthing? i have three spare MTX motors what can i do i also have a hundred thousand machine shops lol its new york lol :)\
egroce11
Taylorsville, Ut.
Mattsho, the block has been bored, deck shaved, crank destroked, high dome forged pistons with dropped pin hieght, rods shot peened and lightened, the whole rotating assembly has been lightened and old school balance on it.
The whole intake assembly down thru the heads has been opened, no secondary butterflies, the heads have been shaved, larger valves w/heavy valve springs.
Running pure N/A
Thanks everyone for the comments, My lady has gotten worse and not expected to be around much longer, money is tight but I'm trying to get out to the sat for theWorld Finals In Oct.
Ernie
victorymike18
Green Brook, NJ
Running pure N/A
Ernie
Sorry to say, I have not seen or heard of your build up to now. A few questions for you:
You bored out a 3.0 or 3.2L ?
Any concerns about de-stroking the crank? I've heard they do not take well to having the rod journals machined, as it removes a friction coating (or micro-polishing?).
Why drop the piston pin height? (I presume to accomodate the high dome pistons?) I have read that ideally, you want to stuff in the longest rod, with highest wrist pin height...
Why remove the secondaries entirely? Not happy with any of the large or HBB secondaries available to use?
I'd be very interested to see a dyno chart for this motor setup. Sounds like it will be pretty mean. I'm a big NA guy, and have a 3.0L awaiting rebuild in the next year or two...
zak
east of Hartford
Ernie's engine is "cheater destroked" to permit a little larger bore thus unshrouding the valves a little. His class (in LSR) requires 3000.0000 cc's maximum. It may require stock rods don't remember.
Ernie will you be running the higher volume 3.2 oil pump?
zak
38SHO
#1 Oil Abuser
North Palm Beach
good to see you still going at it with the SHO Ernie despite other aspects of life.....
besides all of that you are an inspiration for many SHO modders around...
egroce11
Taylorsville, Ut.
Bored a 3.0 to about 3.150
No concerns, my cranks are polished, lightened and balanced. My problems have been oiling issues.
When i say I dropped the pin height it means I droped it away from the piston top towards the bottom of the piston. I did this really to make up for the shorter stroke and give me higher compression ratios.
I'm trying to get as much air in to the cylinders as possible and if you think about it the butterflies and rods are really just a restiction. Once the car leaves the start line it isn't going to be under 4,000 rpm.s.
I posted a dyno chart for one of my motors with these specks and not many people believed it. Yes I'm tooting my own horn but the motors before this one have been reall strong and I'm hoping the this one runs as wll as they did.
SHO_SC Ransom and Lance Chaney finally helped me get the car to run in
4th gear over 6,000 rpm last year.
We still don't know were top end is on this car.
Ernie
egroce11
Taylorsville, Ut.
Ernie, what do you have going for oil filtering and cooling?
I'd like to help with that.
Thanks :hail:
I want to run the setup that Jason showed me in the oiling post and have gotten the filter sanwich but not been able to get the cooler or lines yet, I did pick up the an-12 fittings for the sandwich tho.
Ernie
