rod bearing n oilpump info
shonuffmine
wildchild
sweating balls in fla.pan
how availible are rod bearings for the yamaha and can i rebuild or should i get a new oilpump??? also where is the quickest place to purchase the above items? thanks for any help. looks like when i drop my tranny wednesday to upgrade to the 9*75 clutch i will drop the pan n just get it over with,can,t figure why she,s run like she is but defiently dropping oil pressure at idle,even tho no rod knock.i,m think that funky noise is the cam chain tensioner.once again thanks
elarm1
Maryland Native
Woodbridge, Va
You can get RB's pretty quick from www.RCMautomotive.com, I would definitly recommed changing them while your in there. Clean out the oil pan and pick up with the new RB's and you should be fine.
