SHOrty Shifter
rktmn
Well-Known Member
miami
Just some information on the SHOrty Shifter.
The kit I sell is made up of the following parts:
1) 3.5"X3.5"X2.5" aluminum spacer block
2) steel ball end shifter rod
3) 4 longer machine screws
4) steel collar to attach the shifter handle after it is cut down
PARTS
The steel-ball-end-shifter-rod must be welded to the original shifter after removing the plastic ball cast into the rod. The aluminum spacer will move the pivoting point up 2.5" higher on the shifter, and after shortening the shifter handle about the same amount (2.5"), the distance between the shifts will be greatly reduced .
NEWSHORTSHIFT5
You will have to enlarge the hole in the floorpan, along with the inner and lower shifter box mounting brackets in order to fit the aluminum shifter spacer block.
FLOORPAN
The shifter will now drop from the inside of your car along with the spacer block and the 4 longer metric screws included.
FLOORPAN2
Now you can cut the shifter handle to your desired length, and attach the it back on the shifter with the steel collar provided. You can play with the rotation of the handle to move the shifter **** closer, and when it is at the desired angle, tighten the 4 set screws to hold the handle in place.
SHOrty
The shifter is in 1st gear. The measuring tape show the distance at 7 1/2" at the back end of the shift ****.
FIRSTGEAR
The shifter is now in 2nd gear, and the measuring tape is at 9 3/4" at the back end of the shifter handle.
SECONDGEAR
Total motion is 2 1/4 inches. These shifts are short.
rktmn
Well-Known Member
miami
OOPS, I posted this in the wrong place.
Maybe it should be moved.
Sorry.
jose
rktmn
Well-Known Member
miami
The SHOrty Shifter kit costs $130.00.
I am offering free shipping for the time being.
Jose
Vnuk1
Mr. Mayhem
If I did not have to buy tabs for the SHO AND my Truck I would buy one right now.
Joe_SHO
ND
WTF is holding the shifter up in that second picture!? It's just floating there!?
Ghost93
Rockford IL
Hey Jose, do you have directions to install the short shifter? I dont know what happened to them and I was going to install it soon. Thanks alot, Kevin.
rktmn
Well-Known Member
miami
If anybody needs the instructions to install the SHOrt Shifter, I can send them to you through your email.
You should be able to install the SHOrty Shifter by looking at the photos posted here. It is very straightforward once you cut the hole in the floorpan and the shifter brackets.
Actually, I will post the instructions on the forum.
SuperHO
Mental Patient
St. Joe, MI
mad props on this shifter. I got one installed last year when I had my motor swapped over, and the throws are nice'n tight.
I'm going to second something here....make sure you weld that ball and shaft :laugh_ti: to the lower part of the shifter....it gets ugly if you don't.
Otherwise, high quality piece that makes shifting fun!!!
