my turbo project/setup???
sho_sc
Georgetown, KY
Or you can think of it this way. You take 2 identically built engines and F/I them, 1 S/C and 1 Turbo ...
Given equal TQ, let's say 400 ft/lbs as measured at the crank:
A S/C SHO is flowing enough air "through" the engine to produce 430 ft/lbs. The injectors (fuel), pistons, rods, and crank are seeing 430 ft/lbs. VE is 210%.
A turbo SHO is flowing enough air "through" the engine to produce 400 ft/lbs. The injectors (fuel), pistons, rods, and crank are seeing 400 ft/lbs. VE is 200%.
The turbo SHO has less VE due to exhaust restriction via turbo.
The S/C SHO looses HP to the crank due to parasitic drag.
BlackonBlack89
burlington county,NJ
It's not engine power it's using.
yes the engine losses power by forcing the gases through the turbine. IOW its robbing the hp. just in a different way. not a belt connectted to a supercharger!!!!!!!!!!!!!!
Think of it this way.
N/A car has 1psi of exhaust gas back flow
blower car has 1.5 psi.
a turbo car would have like 4psi- Thats where the power is loss.
Jason you are slighlty wrong. or atleast phrased something wrong!!!:p :rofl:
yamahaSHO
E85 whore
Arkansas
There are too many variables to make a blanket statement like that.
You're not following me. The extra power isn't being made, then soaked up.
OK there's only one way to settle this.
Dyno a car without an exhaust system...just a set of headers. Note the resultant power figures.
Now, strap a turbo to the collector and just let it spin. Re-dyno the car. Note the power LOSS
Next, hook the outlet of the turbo to a sealed off volume of about 200 cubic inches, set up a pressure regulator so that the volume will bleed pressures in excess of 10PSI to the atmosphere.
There, you have all of the losses and none of the gains of a turbo...note your power LOSS... :eek:
yamahaSHO
E85 whore
Arkansas
You do that, then claim your loss. You still fail to see what I'm saying, so I quit.
You have to take into the accout the gains and the loss you're NOT seeing on the engine itself. Try your test, it really won't prove anything to a complete running system. The turbo is esentially fighting and feeding itself.
I've said what I have to say, please use Google for the rest.
92sho16
b00sted
Liverpool, NY
Whatever the losses of a turbocharged engine are I have alot of doubt that they are even remotely close to that of a supercharged engine. Take note that turbochargers are used in many oem applications to increase gas mileage show me a supercharged car that can do this. I don't believe the turbochargers are completely lossless because nothing is perfect there is always friction, air resistance, etc. I have never heard anybody complain about a turbocharger robbing them of power nor have I read this, maybe I was reading the wrong books at school.
Vnuk1
Mr. Mayhem
The op started out the thread just asking for what Turbo to use for 6-7 PSI and this is what it turned into.
Mr. Madison, what you've just said is one of the most insanely idiotic things I have ever heard. At no point in your rambling, incoherent response were you even close to anything that could be considered a rational thought. Everyone in this room is now dumber for having listened to it. I award you no points, and may God have mercy on your soul.
This is not really helping him very much guys.
The engine doesn't spin the supercharger! The alternator does...and the weight of the alternator helps keep it spinning. :biggrin:
AREA 91
Area 91
This thread has failed.
I feel sorry for the origional poster.
Mabye he can find some help elsewhere.
To the other's, take your "smack talk" elsewhere.
SHO_DOODmorrris
Owner & Fanatic
Alberta
i wasent joking...
Edit: obv i was joking just clairifying for those who cant read my tone (n00bz)
randy'sho
95 White MTX
High Point, NC
yeah this post has been ruined by all of you that started arguing over things that are way off target of the original post that I posted! thanks to all that actually helped or realized that this was way off point!
yamahaSHO
E85 whore
Arkansas
With all the people complaining, it makes me want to 'smack talk' more. There was actually some pretty good discussion. If you can't comprehend, don't cry... please.
Sorry about that, Randy. I'll take the blame on this one. I know you are looking for a turbo head unit model number that will provide you with:
Low spool time
Capable of producing boost from xxxxRPM to 7000+RPM
Readily available
I don't know a lot about the different compressor maps, and toolman didn't give you much help so if I had to guess, I'd pick the smallest one from the biggest engine you can find. A low boost Diesel pickup truck with a 5+ liter engine...This will allow it to spool quickly and still be able to handle large volumes of exhaust gas (cause yer spinning the engine a lot faster than the diesel but it's a lower displacement)
Jonathon chose to use a turbo from a LARGE diesel engine so he could get lots of boost. I have no idea how quickly it spins up for him, but you don't need to go that big for what you've described as a target.
