my turbo project/setup???
yamahaSHO
E85 whore
Arkansas
Im going with a GT-30, its good for up to 500 CHP at higher boost, which is ~425 WHP, I plan on hitting between 330 and 350 WHP at lower boost, say 8-10 PSI. It will be much more fun in my opinion then a huge turbo, the max hp/tq numbers wont be as big, but it will make it alot faster then a larger turbo. I want somthing good for between the 0-110ish range, i dont know how often i will even get higher if even that high, but i know daily driving i will be right in that range, so why put a huge turbo in if i will never use it in the speedrange its shines in?
Don't forget to throw in RWD. My motor and blower are good enough to add 200 more whp without hesitation, but I'm already at the point of not being able to do anything with it until 3rd or 4th gear.
You sir, have become a boost snob.
That's as nice as I can put it.
6PSI is a rockin good time.
6PSI is a blast, especially when it's tuned right! Without the parasitic loss of a supercharger, 6PSI on a turbo will pin you to your seat without hesitation. You'll also be able to put the power down easier and have enough reliability to throughly enjoy the power for more than a short time before breaking pistons.
93rev2sev
Hockeytown
I know it's less...but turbos are a bit lossy, too.
93rev2sev
Hockeytown
Huh? There's no extra drag on the engine from a turbo. You're recycling wasted energy.
OK...
I know the losses from a turbo are nominal, but they're there. It takes energy to push exhaust out the tails...it takes slightly more energy to spin up a turbo AND THEN push the exhaust out the tails. There are losses but they are small.
BlackonBlack89
burlington county,NJ
But backpressure is really important to an engine. Thats the main thing. alot of people think a turbo is free energy. it is not however. it is a tad bit more efficent though!
oooo no I am challenging jason.............:duel: :rofl:
OK...
Not as small as you think. I remeber reading about this and turbo's are more efficent but not by a huge margin. Think about it, if turbos are alot more effiecent than s/c, why would s/c'ers still be around? However I would bet with todays' technoloy that turbo are getting more efficent.
yamahaSHO
E85 whore
Arkansas
FLOW is really important to an engine. Backpressure on a turbo can eventually be detrimental, but you'd have to be a complete ***** to take it to the point where it's feeding exhaust back into the engine.
...However, any 'lost' power isn't being dragged from the engine. In addition, sizing the compressor right can completely change the direction (less backpressure than boost and vice-versa). A supercharger will ALWAYS sap power away from an engine that it is already producing. Regardless, this isn't really being seen at the engine as with a properly sized turbo, 6 PSI will put out 6 PSI of power whereas as 6 PSI on a supercharger will produce 6 PSI and then have the SC take some of that power to turn it.... roughly.
To add to that, the turbo is going to overcome the differences. With a good WG, it's going to hit it's target boost and keep it. It will also be able to help overcome the losses of altitude at the cost of efficiency.
Because the each have their use (pro/con) and can take advantage of their different pros in different applications.
Scott's car is able to make more power than me on 44# injectors (the same ones I maxed out) than I can with my 48# injectors at stock FP.
93rev2sev
Hockeytown
Respectfully, I disagree. You can't spin a turbine for free. Period. If the following logic does not convince you, please just remember the most basic laws of physics.
Just like the pully being spun by the crank takes energy away from the engine, so TOO does the turbine take energy away from the engine. I'll grant you this...it does not do it all by itself. A turbo is being spun by gas that is being forced (read using energy) out of the engine. It adds to the omnipresent exhaust losses.
Pretend there was no turbo. Just a regular, quiet, low performance exhaust system. Does that exhaust "rob power" from the engine? Yes. We all know it does. If you open up the exhaust and make it free flowing, you can get some of it back...but not all of it.
To get all of it back, you would need to make the heads open up straight to the atmosphere...even then, you won't get all of it back. That's why naturally aspirated or supercharged RACE CARS use open headers....or even ZOOMIES. To minimize generic exhaust losses.
So the exhaust gas needs to spin that turbine to what, in the neighborhood of 50,000 RPM? It cannot do that without causing the gas to compress, relative to the other side of the turbine blade. I'm not in to quoting the laws of physics, but I'm pretty sure one of em covers that. That air speed "slow down" perpetuates the high pressure zone like a traffic jam perpetuates bumper to bumper traffic...it goes right into the cylinder and plants it's happy ass on the top of the piston...making that piston work harder to expel it. I'm not saying that the exhaust goes back into the cylinder, just that it has to wait on the onramp longer for traffic to clear.
Before I hit "post", lemme ask you a question.
If you could make an electric motor spin a turbo (in the open atmosphere..no pressure against the outlet) to 50,000rpm, how much power do you think it will take?
Remember...you are spinning TWO BLADES...no cheating and removing the exhaust side of the turbo...you have to spin that, too.
BlackonBlack89
Power is not being lost by a belt... Yes, BUT power is being lost from backpressure. This means that on the exhaust stroke, the engine has to push against a higher back-pressure. Which is a loss in power. The loss is not as great as a s/c but none the less a loss.
Sizing a turbo (turbine) only increases or decreases the amount of backpressure. For example on t/c'ed road-track car the turbine is alot bigger to allow exhaust gases to go around the turbine, which means less back pressure at low rpms. As rpms increase back pressure increases as more gases are pushed to the turbine. As backpressure increases u are lossing power, which some of it is made up by the psi being produced, but not all of it. Ie at 10 psi it has to fight the exaust pressure(which increased) which produced the 10psi to begin with. ( ok I made that last sentance up but it makes sense) anyone verify this. :rofl:
Actually on the first comment. Not really to hard to do. A simple cam swap can cause that and show its ill effects.
92sho16
b00sted
Liverpool, NY
This is true but let me ask you this can you put your hand on your exhaust after the car has been running? A turbo recuperates wasted energy from the exhaust this doesnt mean that it is 100% efficient but it is more efficient that a supercharger.
This means that on the exhaust stroke, the engine has to push against a higher back-pressure. Which is a loss in power. .
Yes a turbo increase the restriction in exhaust flow but you need to also take into consideration that the is increased pressure on the intake and flowing into the combustion chamber which helps evacuate the chamber.
....... for example On t/c'ed road-track cars the turbine is alot bigger to allow exhaust gases to go around the turbine. which means less back pressure. .......
Are you trying to tell me that if i size my turbine correctly i dont need a wastegate because that is the only way i can interpret if the turbine housing is large enough gases flow around the turbine that does not make any sense at all that defeats the purpose of a turbo charger.
Also superchargers are still around because like jason said they have the pro's, there are many different types of superchargers. Centrifugal types like the vortechs are said to be similar to turbos in the sense that they can have some 'lag' becuase of the distance between the outlet and the intake manifold but they still start to build boost instantly something a turbo charger cannot do. Roots type blowers elimate this, i dont know much about them but top fuel dragsters wouldn't be using them if the were inferior to turbochargers.
BlackonBlack89
I know it is more effiecent. (In theory may I add. LOL) but yes it is more efficent I have said this. What are u trying to say about heat?
That changes with a turbo charger as back pressure can overcome the intake pressure. Thats a simple answer. as there are many varible to this. Ie cams, turbo size, downpipe, ect. A s/c on the other hand is alot like a N/A exhaust pressure. A tad higher b/c same space but more gas.
No. It means at low rpms it will do nothing. It will spin(duh) but will not produce any pressure. Also making the backpressure alot less until high revs are seen. IOW lots of lag...... Thats all. Some race turbos actually have much larger turbo housings than the turbine itself. Better flow charactersitics at high rpm. hence a race turbo. suffer down low but its a race car WOT all day.
A W/G only controls boost. it works the same with a small turbo or a big laggy turbo.
And let me make this clear. I am not aruging that a s/c does not steal its power. It does. I know that. but A LOT of people think a turbocharger is FREE energy. That is 100% false. IT IS more efficent than a s/c. I said that on my 1st post. But both forms FI are not free. Plan and simple!
And I know the pro/cons of a s/c'ers and t/c'ers.
yamahaSHO
E85 whore
Arkansas
Of course it takes something to turn it and it will add 'resistance' to the exhaust, however, this isn't dragging off the motor. It's not robbing power that is being made like a supercharge will. That turbo is also what is giving the exhaust the extra flow as it revs up and give it more power.
Actually, you can use an exhaust to gain and make power more usable... Two-strokes operate on this theroy. A proper exhaust will help the exhaust evacuate without turbulance from the head port. If that were the case, we'd all run 4" exhausts.
Headers are an exhaust. It HELPS in getting those exhaust gases out.
With a properly sized (mapped) turbo, that turbo isn't going to be causing much of a back-up in it's efficiency range. The turbine is already howling along, it doesn't take a ton of to pick up the pace.
In a sence, that turbo is spinning itself. It's being turned to force more air down the motor and not taking (like underdrive pulleys) the power off what the motor is making. I've personally found that you can get away with a smaller injector with a turbo with just working with SHO's than you can with the trusty Vortech. I'm maxing out 48# injectors (95%+ DC) on my Vortech and scott is in the 70% range DC on his turbo running 44# injectors (MY old 44's that I was maxing out at less power than he's got). Our motors are pretty closely built.
However, it's not making the extra power to turn it. IE: 400hp turbo SHO is consuming about 400hp of fuel. A 400hp SC SHO is probably actuall consuming 450hp of fuel.
As that backpressure increases (not as much as you think since the turbine picks up speed), the compressor side is also increasing and forcing that air into the motor.
They use larger turbos because they are road-track cars. They're never under 5k RPM... No need for the low end power. If they're sizing the housing larger than normally needed, it probably because of expansion properties of 2,000+ degrees of constant heat.
Considering that it's essentially not burning any extra fuel for something you'd never see, I'd call it 'free'.
When I boost my next toy... whenever that is, I'll go the turbo route this time. With the SC, I do like that I don't melt anything around it, but I don't like the extra bearing wear from a tight belt and the extra power it takes to turn it to reach the same 'seeable' power as respective turbo.
Toolman
Boost it!
Grand Lake, Oklahoma, USA
What is it dragging/robbing power from then Jason? Put a restriction in the exhaust (which the turbocharger is), and the engine will make less power. Yes, a properly sized exhaust driven turbocharger is generally going to be more efficient than a belt-driven supercharger, but they both need an outside energy source to spin them.
But it still used power to spin. It uses MORE power as it spins faster and makes more boost.
And what do you think is happening on the compressor side as the turbine picks up speed? The faster the compressor spins, the more resistance it encounters, and therefore the more power it takes for the turbine to spin it. While it may get more efficient at certain rpms, it still uses MORE power the faster it spins.
I am all with you there. Turbo powa!!
yamahaSHO
E85 whore
Arkansas
It's not engine power it's using.
bmytych
