Wiring cda 7995 to factory amps?
Brandontw
Reno, NV
As you may of may not know the Alpine CDA-7995 does not have an internal amp, but 3 preouts i want to use the factory amps for now wired to my new head units but i need it in the form of rca's to connect it to the ne HU any Help?
93medusa
Stamford CT
I had this exact set up. It sounded great. What I did was this: there is an eight pin squarish connector with a gray wire running to the back that attaches to the back of the head unit. This wire is the preamp wire that runs to the factory amps. I had a wiring kit that had a plug that attached to this wire and wire leads coming out the other side labeled for which speaker they went to. I simply attached RCA connectors to the proper wires, and plugged it in. It worked flawlessly. If you'd like, I'd be willing to sell it to you, but I would recomend using some better RCA connectors, since the ones I used were cheap ones I stripped off a cheap set of RCA cables. These would work perfectly http://www.partsexpress.com/pe/pshowdetl.cfm?&DID=7&Partnumber=091-1265
Let me know!
crystizel
