Window problems
Jrodm12
Wa State
My passanger side window is broken.... sometimes the switch works sometimes it doesn't i have swaped the switch with one of the back doors same thing. Any idea's. Do the motors go bad?
~Jared
~Yakima,Wa
~89 SHO 130k Flowmaster 40's, K&N filter.
oh_SHO
Ohio
I have a smiliar type of problem with the driver's side rear window. Works fine from that door switch.The master switch won't put it down but will roll it up. When I hit the master button to go down I can hear the motor start to move then it just stops. Yes I have swapped out the switch. Think its a motor problem or...??
morpho18
Des Moines, Iowa
is it just me or do sho's have problems at the same time? i can roll down my passenger side window from the master control, but can't roll it up.
Camarok
Awesome SHO Member!!
Milwaukee, Wisconsin
well the one way switch is usually because it's dirty.... do both functions work on the switch of the window itslef and not just the master?
Jrodm12
Wa State
no its not the motor i am thinking electrical cause i put the switch back on and took my mom for a ride. Bad idea. She rolls the window down and it won't come back up. I get home and spend a hour trying to get it back up and finnaly i push the driver side master switch to roll up the passeger window and goes up without a problem.....
Camarok
oh boy... it looks like it's time to get out the multimeter and look for shorts in the system ( not the most fun but you should do it ) you want to check v12+ coming into the switch and to the motor and grounding and all of that
what year sho do you have I've got a wiring schematics book i can scan and email them to you if you want
oh_SHO
Ohio
Think we are both having the same problem with shorts in the wiring? I'm not about to tear my car apart for that. I'll just keep reaching behind me to roll it down...
NiNeTy Fo SHO
No-mo-SHO Man
Troy, Ohio
I had a problem like this...and I have one now...before I took the master switches out of the door and cleaned up the contacts that the switches make. It worked for about a year and a half. Its starting to do it again with my passenger window, but to get it to work, I just tap the drivers switch 3 or 4 times or until the window starts to move, and then hold down the switch...
Im just too lazy to fix it right... ;)
You usually dont have shorts in the wires...its either the contacts the switch makes or the motor itself..
Camarok
It's wouldn't be under the carpet... it would be breaks close to the connections like right at the switch or at the motor and i would really look at the switches again
oh_SHO
Ohio
Well, I'll check the switch again by swapping it out with a known good one. If that doesn't work I might swap in wiring from a different door since I have a parts car. :D Thanks for the help.
Jrodm12
Wa State
I have a 89 sho with 130k and yea if you could email me the wiring schematics that would be whille before i have time to rip out the panel and everything. I hate working such long hours but to pay off my new car, it is worth it!
Hiboost
TN
I replaced my master switch....and its started again...only up using the passenger window switch
ohioshodude
SHO'ld fogy
delaware, ohio
this could also be a problem like i have on the 91. . when both doors are closed the rear drivers window will go down but not up with the master switch. when i open the front door the window works correctly from both switches. both switches work fine i'm guessing a wires is cracked in the harness thats between the door and the frame. (talk about infuriating when trying to install custom window switches) might be something similar with you. i replaced everything switches/motor/master switch only to discover its in the wiring in the door.
LeddZepp8687
The Keg Rider
Naperville, IL
Wow, just tonight I had this problem....I picked my friend up from work with 3 people in the car already, he went to roll down the window to have a smoke and it wouldnt go down, he says "can you unlock my window" and I unlocked it but his side was dead and the other side was fine (rear windows) Neither the master switch or the switch on that door worked....I dont get it, it worked a week ago but now its dead......
ES_8CH_OH
White '94 ATX
Malvern, PennSHOvania
My driver side rear window will not move up or down. Neither the master or the door switch will work...
Any suggestions?
