Window issues
RosieK76
Vidor Texas
I have a 2011 ford taurus sho and only the driver control panel can roll down all windows, if I have passengers they can not roll their own windows down. Any idea what I need to troubleshoot
Joshw0000
North Carolina
Sounds like the passenger controls are out if the driver controls still work. But before you tear into the door panel, check your manual and see if there are any fuses related to the windows and check them all.
Sent from my Pixel 8 Pro using Tapatalk
iirc all passenger switch panels are routed thru the driver's switch panel. so def start there first. hopefully its just the lockout as TM said above.
RosieK76
Vidor Texas
Ok thank you I will get my mechanic to check that out
Texas Marauder
Lone Star State
Likely a bad master switch or loose or broken wire. The power to the other 3 switches goes thru the lock switch.
1718809573327
1718809643026
1718809691862
