Erick
Well I have a 94 ATX running good exept that it started overheating last night on the streets I pulled over and checked to see if the fans where working (on) they where not, the temp gauge was almost in the RED past the Normal I turned on the A/C Max and the fans turned on but the temp gauge went past the RED, and I also notice that my RPM Tach stopped working but the Speedometer works, Autolights stopped working, the warning lights in the cluster stop working ( oil, brake, seatbelt, low coolant, check engine light) all of those ligths are inop except for the battery light, when I turn the ignition key on the red Battery light is the only one that lights up!
Today after work I checked for codes using the paper clip method, but the check engine ligth was not flashing at all, but I was able to hear the fans turn on and the fuel pump cycle.
Well Im thinking maybe its the CCRM from what I've read hear in this forum seems to be a common problem with the fans not working properly but I dont know what to think about the Instrument Cluster warning lights and RPM Tach not working and also the Autolights stopped working???
Any Advice on how to diagnose this problem would be appreciated. Thanks in Advance
