Why is Unleashed tune less expensive than LME?
BigB15
GA
Actually fastest was
1st pass 13.14 @ 105.29 1.911-60ft
2nd pass 13.19 @ 104.66 1.934-60ft
Then several 13.2x
Did you try removing the rubber strip along the firewall/windshield cowl? That allows some of the heat to escape from under the hood, may help your ET's a wee bit.
SHOnUup4
SE MI
IAT2 temp is what cuts my runs each time. After 2 runs and sitting in staging lanes for any amount of time and mine hits about 135-140. Meaning it's cool down time. At that point you can feel the launch weaken from sucking the hot air in the box.
Rich
Has anyone with a tune experienced any wheel hop in the 1-2 shift under full throttle?
Usually something to do with the tire type, tire pressure, and/or ambient/surface temperatures. Easing up on the shift (either lowering power or shift pressure) can help also.
Livernois Motorsports
SHOForumSponsor
Sponsoring Vendor
Dearborn Heights, MI
The culprit is going to be the traction control, advancetrac and stabilatrac...if your car is a PP car, turn those nannies off. If it is not then you can use the left set of steering wheel controls to turn the traction control off.
Calgary
Alberta, Canada
I agree with that ^^^. Nothing against Torrie or the other guys, it's just that Livernois has the ecobeast figured out.
Still waiting for the dataloggers to catch my 12.54 also. Meant in the friendliest have a beer and talk smack kinda way.
Rich
what mods?
Calgary
Alberta, Canada
Livernois 3bar tune, CAI, tstat
Rich
1.25 gallons of corn per 13 gallons of 93 too.
Rich
Wow thats phenomenal lol how aggressive a tune, was it the 4+?
Im gonna goto an awd dyno for a baseline next week then im ordering a new thermostat/3barmap and LMS intake with a order of a tune and installation of a tune and 3bar at a later date. along with a corsa at some point. whats the fastest unleashed time with CAI, 3bar,thermo, and a tune? I have access to 94 octane with 10 percent ethanol. and 91 v power without any. how much extra power does the 94 with ethanol provide as opposed to the 91? also does the extra octane point count for anything?
SHOnUup4
SE MI
Tune ran was the 4x plus 93 octane...the higher octane will give you a comfort zone to protect against pre-detonation and a slight bump in power.
I just ran a 12.42 this past weekend at opening day for Milan.
I don't know the best times out there for Torrie...but I'm pretty confident I've now secured the best time at this mod level regardless of tuner.
Nice plans you have for the future, keep us posted.
Rich
Calgary
Alberta, Canada
Rich
got any on youtube?
