greenbeanmtx said:If your car has fog lights you can just wire it into the fog light switch. On my 93 thats how i had them and they dimmed with the dimmer and everything. I see a gen1 in your avatar so im not sure if its the same way there. Ive got an 89 so i cant share the glow gauge bliss anymore![]()
Eliw said:Though I may soon swap the interior of my 89 with with that of a 90, I will still continue to try to work on an 89 gauge cluster retrofit with that of a 90 and above. Once I get the first one done, I will attemp to write up instructions, or even sell it if I do end up swaping my interior. The bandit may just get halo gauges eventualy![]()
Eliw said:While the group buy would be great, I truly want to update my gauges though. While the SHO 89 gauge cluster is like one of many unique 89 parts, I preffer the more rounded gauge clusters.
Using a bit of careful cutting, you can install your OWN guages and keep all the surround dummy lights. The surface of the cluster is flat, so it wouldn't take much cutting and mounting to make this work. I plan on running my own tach, speedo (more like a 180mph), fuel, temp, trans temp, and oil#... Imagine a USEFUL cluster!!
