92ShoOff
Well I decided here in a few weeks I'm going to tear the bottom and top end of my motor back apart and change all the gaskets and do the rod bearings, main bearings, and the piston rings.
So question for today is: Where should I get these bearings and rings from? I know AutoZone has them, but where would all recommend getting these from? AutoZone has .000" .25mm, .50mm, and .75mm rod bearings, and same thing for the main bearings. They're piston rings are available in .000", .010", .020", .030", .040". How do I figure out what I need for the bearings and pistons? Can I do any of this with a feeler gauge or something? I'd hate to have to find a way to get the car to some shop with the motor all disassembled to figure out what I need. I had to redo the rings in my El Camino because I over-revved it one day.... but it had a new block with 2k miles on it so we went with the standard size rings from Keith Black (which was what was already on there) after re-honing the cylinder walls.
And about how much $$ am I looking at to do all the bearings and the rings? I hope not more than $300 or so! Thanks everyone!
-Andrew
-Andrew
