Where can I get a single stainless brake hose?
TRSCobra
Washington
I put those russell stainless brake hoses on my car, and the way I routed the left front, the tire rubs against it. It's probably okay, but the clear coat stuff is gone, and the braiding is starting to wear. So I want to replace it, but I dont wanna buy a whole 'nother set!
Does anyone know where I can get just that single hose?
SHO Continental
Moderator
Northridge, Cali
I had a couple made by this shop close to me..
don't worry about that line.. took that pic when I put on the correct size pads.
mine are an inch longer then stock lines.. I should have had them go longer so there'd be more slack with PBR calipers should I decide to upgrade.. but I'll probably get some earls later..
Todd TCE
Tempe, AZ
Orme Brothers does the majority of my Goodridge hoses now.
You don't have to have a local shop, they'll ship to you direct.
818-885-1414
S
shoebilly
Guest
As long as the steel braided wire is undamaged the hose is ok. These lines can't rub on anything. The plastic coating on the outside has no effect on the strength of the hose. If one steel strand is broken the hose can/will fail.
TRSCobra
Washington
Well, i would imagine after some time rubbing against the sidewall of the tire, the strands must show some wear. Its just too cold to do anything about it right now. I don't drive it that much anyway. 1,500 miles since thanksgiving :)
