What is this sensor? (checkout pics)
dastuph
Missouri
I was putting a new neutral switch in my 95' ATX and while I was there I noticed a sensor just below the neutral switch that had a VERY frayed wire going to it. Intend to make some sort of repair to this wire but I'm not touching it till I know what the heck it goes to. Checkout the pics below. One is a wide shot and the other is a closeup (as I could get).
Anybody know?
Wideshot:
Closeup:
Thanks ahead of time.
sho'd
Git R' Done
ontario,canada
that looks to be your TSS sensor on your transmission. Turbine Speed Sensor. those wires look awfull.
dastuph
Missouri
Thanks again, your a wealth of knowledge. This is next on my list of fix-its. The SHOs got 178k on it and the exterior/interior look incredible but I don't think it was mechanically taken care of at all. I've done alot of "maintenance"...to use that word loosely.
I'm sure I'll have more questions later...
sho'd
Git R' Done
ontario,canada
not a problem, when i can help i will! you can go to the scrap yard and almost any taurus will have that conector, as long as it has a axode transmision, find one with good wiring and snip it so you get as much wire as possible and either use butt conectors, or solder it in. i know how it is, when i started out 1.4 years ago, man if only you knew the stuff i have replaced fabbed up, but it's a good hobby and lots of fun at 7000 rpm!!
crystizel
