What is the DIS
SRGUYINDAVIS
Davis, CA
I am trying to troubleshoot my car and keep reading about the DIS, I am curious what it is and where it is loacted on a gen 1
SHOtimer
#2910
Santa Clarita, Ca
It is the 'brain' of the ignition system. It takes the readings from the crank sensor, the cam sensor, and runs the motor. It stands for "Distributorless Ignition System" - I think. If you are looking at your motor from the front of the car it is the gray rectangular box on the crossover tube on the passenger side of the engine bay. With one plug on each end.
Doug
Bringetto
What broke now?
Cali USA
ive had to replace my DIS, if your car runs ok and as you drive gets worse and has little power and soon wont rev, it might be the DIS module, if you run codes and i gives coil pack codes im sure of it
SHOtimer
#2910
Santa Clarita, Ca
Just because your SHO does this does not automatically mean the DIS is bad...
Doug
Bringetto
What broke now?
Cali USA
Doug
No, i wasnt trying to put it that way, just i spent 7 months working on it replacing $800 worth of parts into it to find out i had a bad DIS witch i changed in less than 5 mins
