For the last two weeks my engine has been intermittently misfiring. The SES light pops on, the engine starts to run really rough, the RPM will drop to 500 when idling and only run up to 1700 RPM at 70 MPH. It comes and goes just like flipping a switch.
The codes I am getting are;
KOEO: 216 (Primary circuit failure – ignition coil 2), 212 (Ignition Tach signal was erratic (module/ wiring) or Spout circuit fault).
KOER: 167, 225 and 116.
Any ideas what this may be?
I initially thought it was my fuel pump that finally gave way. It was always pretty noisy, but for a three day period it was just a really loud whine. Now I can still hear it prime before starting, but the excessive noise is pretty much gone. Do these pumps die so slow that they will cause the engine to run the way it does?
Also, I had water leaking into the passenger side floor compartment and am thinking this maybe has caused some damage to the ECU? Is there a way to check?
Checked the grounds and they seem fine.
Any ideas what this may be? Thanks in advance.
