Well, The Front 60K Will Begin Soon!
SHO_ROLLER_2
Well-Known Member
Branford, Fl
I have finally ordered all the parts:woo-hoo:!!
I think I'm going to do the work myself and save $300. I figure if I use the guide off of SHOPhoenix and go slow, I should be OK. I'm just worried about screwing something up and not knowing untill I put it all back together.
I CAN'T WAIT!!
beaudeen
BEAUDEEN
Shannonville, Ontario
Just finished my first 60k 10 minutes ago...started right up,,no grinding/scraping or squealing...only thing that screwed me up was searching for long enough bolts for the crank puller. Also a good time to change the front engine mount if you need one..mine was SHOT big time..I'm just going to change the rad hoses as they have seen better days..other than that..I used scrap cardboard and punched the bolts through marking where the bolts went for the 3 timing cover pieces...took my time cleaning everything before putting it back together...not even a cut or scratched finger...until putting the wheel well shield back in,,lol
