well i found something
N
neg1ohs
Guest
i pulled my intake off and found a few surprises so then i fixxed it and put the intake back on and now the car wont start.this blows im getting sick of this car.i put 3.2 injectors in cuz i had a bad injector.
dantheman68
Kinda Big deal
Pewaukee, Wisconsin
was the manifold tightened enough/evenly... is the ground on the rear left manifold bracket? did you connect the DIS...
its probably nothing big...
N
neg1ohs
Guest
well the car was on e right b4 i turned it off to do the injectors like dead e so hopefully its just that.gonna tighten that crap tomorrow it was lose when i took the mani off.
smokin joe
Milwaukee WI
What did ya find? and chances are that its with the DIS did you have it off at all? make sure that its getting grounded good, it gets grounded by the bottom 2 skrews only, i would check that and the ground on the back like dan said its got to be something simple if you only had the mai off
N
neg1ohs
Guest
yep didnt have it grounded.well i found out my knock sensor wasnt hooked up 1 injector plug harness was ******.and 2 other ones were only connected by 1 strand of wire.
N
neg1ohs
Guest
cars alot better now rewired the injectors and knock sensor.and it actaully ahs top end now.
N
neg1ohs
Guest
red89mtx said:
so u ready to run me agian lol get on aim
youll prolly get me again hopefully not as bad i need to spend some time on my mx6 havent worked on it in a week.i was thinking about getting some cheap raptor mufflers from farm and barn some of my v8 buddys said they sound nice and i figured anything is better then stock mines got a hole in 1 of the mufflers.
plethaus
Kittyland Love Center
If either of you guys want to race, meet me on hwy164 sometime, between the 43 and where it branches with the 59.. it's dead during the day, I've basically never seen a cop on it :evilgrin:
N
neg1ohs
Guest
just changed the fuel filter looked clean filter was prolly good ohwell.so about spark plugs can i just get them from a parts store or do i need to go to ford?
N
neg1ohs
Guest
id race but my check engine light still comes on
running elan and tps and knock sesor.so prolly need to replace the oxy sensors and the kncok sesor even thou shophoneix says ignore if you hear no pinging.
