My recommendation, if you want to follow the leaders
, is to get yourself the EBC slotted (or plain if you MUST) rotors with EBC yellowstuff (bpd) or redstuff (many others) combo all round. Day in, day out performance on the street or strip. Not heavy duty autox though.
You can also go with a Power Stop kit, or OEM rotors & EBC pads.
OK, so I shopped around quite a bit, and found out that EBC kits are way, WAY more expensive than Power Stop kits. Found a 4 wheel PS kit for $340 IIRC. That's close to OEM price. So, question is... are Power Stop any better than OEM? If so, by how much? I've not Autocrossed the car, and currently have all OEM hardware, and until recently felt good about how well they worked for me. (Light years ahead of my last Taurus, a 2004... had brakes softer than a pillow.)
Anyhow, since I don't autocross... if Power Stop are better than OEM, then I'm happy with that. Even if I did Autocross, cutting the life down in half might be OK since they're half the cost lol. However, if they're kinda crappy, not quite OEM quality, then I will give much, much more consideration to the EBC kits, even if they are much more expensive. I'm not cheap, just occasionally frugal.
So, bottom line, are Power Stop Z23 Evolution Sport any good??
Also, why the objection to "plain" rotors? I've been doing a TON of reading and YouTube watching over the past few days, and it seems cross-drilled and slotted rotors, once really beneficial for heat and sweeping away brake dust, etc., also leave the rotors weaker than plain "OEM style" rotors - and some claim that modern brakes don't really need slots or holes at all - that it's really just ornamental at the expense of wear and tear... so what's the deal? Any good hard data to support slotted and/or cross-drilled rotors these days?
