Water Pump!
91 Plus
Well-Known Member
Monroe,Michigan
I changed my water pump about a year ago..Got upper and lower radiator hoses already..Today on way to school low coolant light came on,i stopped and damn resviour drank the hole gallon of coolant..I have to find out where it is leaking from..I would hate to have to change the water pump again!!
Yamaha V6
SHO Enthusiast
Rhode Island
Better to find out now than in a couple of months! Did you JUST change the upper & lower hoses? If so, double check the clamps. The overflow tank itself is also a known culprit for leaks, as are the heater hoses.
Good luck!
91 Plus
Well-Known Member
Monroe,Michigan
The hoses have been on there for a while.At one time I had a problem with leaking hose that connects to the intake!The question about the heater hose now..This morning I heard a weird grinding type noise when the heater was on.I turned heater off and noise went away! Hard to explain the noise it was making!I turned heater back on and it went away.I had radio up loud so I dont know how long it sounded like that!Thanks
I recommend that you find the leak before you worry about the pump or the hoses you recently replaced. Check for the end tank seals on the radiator. You have to find the source before you can fix the problem.
91 Plus
Well-Known Member
Monroe,Michigan
sdpatt:
I was goign to first.I was just wondering if anyone ever have problems with water pumps going out that fast..I will check after I get out of school today..I just hope there is still alot of coolant i have a hour drive!
Aren't you going to fill it up before you go? Why not take some water with you too? You do not want to overheat the SHO engine.
91 Plus
Well-Known Member
Monroe,Michigan
sdpatt:
I already got a gallon and put it in there!On the way to school I stopped off right away and filled it up! When I got out of school 5 hours later there was little on the ground..But it looked like it went out the resviour and over cause i put little to much in!!
