Water pump dead already?
Devin
3.Slow
Pacific Northwest
Been leaking coolant for a couple months now, almost immediately after changing water pumps. Finally took the timing covers off and it looks like it is the weep hole. Is there a way to install this improperly that would cause that, or is it just a dead pump?
249
Devin
3.Slow
Pacific Northwest
Probably shouldn't be able to see something shiny through here
251
Ridiculous. Changed the water pump preventatively because my crankshaft position sensor was failing and this one fails catastrophically in weeks.
Irish Pride
Irish Inside
MusicCityUSA
If it's leaking out of the weep hole then the internal seal failed. Nothing you could do about that. Hopefully you can warranty it out at least.
-Chad
shootinirons
