warning "ding" issues....
faxon
Seattle, WA
I just recently had my ignition cylinder (the place you insert the key) replaced on the 1993 MTX. Now, every time I open the door the bell goes off, key in or no key in. This should not be. Short of pulling the bell's fuse, what can I do to make the bell not go off when thee key's not in?
sho 'nuff
Kansas City
My car has the same issue...I think its a short somewhere because if my steering column is tilted up all the way it will stop. Anyone got ideas what it is?
'93 green atx
LeBra mini-bra
gts headlight blackouts
Blue Fishtanks
bosch platinum +4 spark plugs
RActive Heat shield filter
Hayden TransCooler
xenon head and foglights
12" jl audio power wedge box
200w kenwood amp
NEONS!
Cobria
Saint Louis
My Sho has always dinged when the front doors are open, key or no key. I think this was a factory design.
thebetterman
Canada
my dings sometimes but if I take the key out in the right place or if I play around with the position of the ignition after the key is out it stops dinging.
1992 Silver MTX
Completely Stock
fredhurderjr
www.neshospecialists.com
ditto, betterman.
White 95 SHO MTX
"Jezebel"
Spends more time in the shop than in the driveway
Teases me with occasional great runs
3.2L SHO Shop Long Block
9psi Vortech S-Trim Supercharger (12psi on the way)
Eibachs, Tokicos, 96 Brakes, SFCs, STBs
PP Y-Pipe, Custom Stainless Cat-back, Bullets
http://members.home.com/fhurderjr/sho.htm
94shoboy
south shore, mass, usa
i had the same problem in my compnay truck, 94f-150, i opened the door, found the buzzer thingy and stuck a small nail through it
no more dinging.
Da SHo sToPpA
SHAOLIN
I have the same problem. About a year ago I snapped my key in half in my ignition!!! Don't ask how. Only i could pull a stunt like this. So half the key was stuck in the cylinder and I had to shove the other piece in and turn. It took some skill to get it going. But anyway I went to a locksmith and they put a new cylinder in and I have the same problem. Damn its annoying...
John Andrews
93 Emerald Green Mtx
GTS Headlight Covers
Illuminated Ford Emblems
Coneless
K&N Panel
FordLover
Houston, Tx
there is a small switch that senses when a key is in the ignition, the spring loaded thingy must have broken, making it think there is always a key in there. I wish I could remember how I took my ignition out...
-Martin
92 Silver UDP's, coneless, Alum SFB, SHOnut motor mounts
93 Green MTX, High Rev's Jr, lightened flywheel, grizzly paw TOB, fishtank lights, SHOnut motor mounts, K&N panel, coneless, SHOshop linears, tokicos, alum SFB, 26MM RSB, wigwag headlights, 225/55ZR16 firehawk SZ50's
94 Explorer Sport *sold*!!10-6-01
Gez89SHO
LEGO SHO
NE Philadelphia, PA
My ignition switch is worn so that you can take the key out before it locks closed - now it will think you still have the key in there, it will ding and you can even start the car without the key!
To make sure it locks, I sometimes turn it without the key until it locks. Now it won't ding and also you can't start it.
Gezim
1989 Currant Red
coneless, painted SHO lettering
Subframe Connectors, 16x7 Team Loco 143's
gzim.freeservers.com
LSHOC member
[email protected]
cobrakidd03
michigan
Ok I am digging up a really old thread here but I have the opposite happening. I just replaced my ignition cylinder and I have no ding, ding when the key is in and the door is opened which is fine by me. Any ideas to why? I know I said it was fine but just knowing that it doesn’t work as it should bothers me.
hawkeye18
Sorta cares
Norfolk, VA
there is a black/purple wire that goes to a very small plastic piece with a copper spring in it (all smaller than a fingerprint) that slots into the bottom of the ignition cylinder right on the outer lip. Personally, I #%*$ing hate that dinger, and between the fact that a) I don't need the keys to start the car and can remove the keys while it's running and b) I have a freakin' keypad if I forget my keys, I cut the plastic off the end of the BK/purple wire and taped it. Now, it still dings if I left the headlights on with the door open (useful) and doesn't ding if I left the keys in, cos frankly I don't care.
Hope this helps somebody. If your dinger isn't working, either the wire isn't there, the copper piece broke off, or something else isn't making a connection.
SHOGUN88
1994 MTX
Langley, BC Canada
Mine does the same thing just the headlights the rare time i use the switch, very rarely with the key in but i like it that way, its annoying as ****.
cobrakidd03
michigan
Oh I couldnt be happier that the ding ding is not there anymore. before i replaced it it would be going off when the key was out. But I just found it odd that it has stopped working with a simple change i made
JRA2000TL
The Complainer
Daphne, AL
That little wire with the metal clips that "clip" or fit on to the ignition probably came loose and it sometimes touches the ignition causing the ding to go off. Mine has the intermittent problem of tilting the wheel up and it dings, tilt it down and it stops. I'm not sure how it stayed put from the factory but I put it back in place when I took my ignition out once and it still does this. I'm weird but I like the ding...sometimes it gets annoying when you're cleaning the car and have the radio on and doors open at the same time.
I think they changed the tone of the dinger in the 90 model with a higher pitched chime than the one in the 89. The 92-95s seem to have an even higher pitch in tone.
