Virtual Dyno Day!
skyshadow07
Oklahoma
My best bet on why it was so messed up is because I used a HP tuners log
FiveLeeter918
Ortiz Performance Sales
Tulsa, OK
Just export it to Excel, crop out everything but TIME, RPM, BOOST, AFR, and THROTTLE. Remove all the heading information from the file and save it, crop the file down to JUST the pull nothing extraneous, and then open VD and go to Options -> Columns and headings and force it to look for those items. Then load the file in and make sure gearing matches.
ridered74
Try smoothing setting 3. It makes the graph smoother and you lose some power number wise but I noticed lee used 3 so I did too.
Lowered the torque a bit but the graph looks pretty much the same. If I put smoothing at 0 my torque goes up to 781 ft/lbs. All the powah!
802SHO
Boost > VE, MBT, Cams
Essex Junction Vermont
According to virtual dyno.............after adding the phenolic spacer and nothing else changed on same tune and same road......I lost 75awhp and 44 awtq! Hmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmm3023D6F8 A630 4BD9 83C0 B0606D94CBA3C3C3BEF2 8E8E 4145 BA5F C0971FA03A53
Ecoboost_xsport
Sacramento, CA
According to virtual dyno.............after adding the phenolic spacer and nothing else changed on same tune and same road......I lost 75awhp and 44 awtq! HmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmView attachment 15116View attachment 15117
Hmmm these are interesting results...
Able to get more data? Don't have mine on yet, but if others who have it can get some logs to corroborate. I'm wondering if a tune revision is needed. Lots of work, sure, but maybe pull it off and do another run to verify? Also, not sure how much it would effect it, but it's got a very sloppy fit due to the IM bolt holes so large and alignment may be interrupting flow? I've got the alignment dowels that may facilitate this. Idk just throwin stuff out there to think about.
I just can't see how this small 3/8" spacer could effect it that bad (or even improve power, tbh), I was intending on using it as another step in heat soak mitigation.
Another issue I have is really with Virtual Dyno. It just changes too drastically with even very small variables or adjustments. I could never get anything reliable out of it so I kinda gave up on it.
Good info though and we should all look into this a bit more.
802SHO
I agree about the reliability of virtual dyno. I think it is a great for giving someone a ball park idea about power out put but it is very finicky. All of my last year 19 psi 3rd gear pulls without everything I did this year had me at over 600awtq with smoothing at 3. What I also wanted to state was that otherwise the above pull felt great actually. I was eager to check it with virtual dyno. A Dragy pull would be my next test. Also maybe check the tightness of the bolts.
Ecoboost_xsport
Sacramento, CA
Yeah, service manual says 89 in-lbs, so it's not that much. Hopefully that doesn't crack that material, either. I still haven't been able to bail down what actual type of material he used, although it looks and feels pretty sturdy.
My logs do that curve back too, and are way down on power.
I don't have the spacer. I was noting my VD dyno logs are curved like Andrew. They are down on power from my actual dyno runs as well. It says I have 341 hp and 420 tq. My dyno runs on numerous days have always said 390 hp and 470 tq. 111 mph @ 4560 lbs is roughly 487 flywheel HP. 487 hp x 23% = 112. 487 - 112 is 375 to the tire.
High on Ethanol
Just Ain't Care
USA
Do you have any airflow numbers?
On my 391/470 dyno run, I pulled up my data log.
Ambient Air Temp: 78 degrees
Fuel: 91 octane mixed with Torco T85 for E30
Load x RPM x .00471
1.62 x 6293 x .00471 = 48.01
ridered74
If you have excel, just compare timestamps from identical mph's between the two tuns, 30-80 or 40-80 or whatever you ran. I've done that numerous times on 1/4 mile runs and it's always within a hundredth of a second of what dragy gives me.
I wouldn't sweat a virtual dyno result.
FiveLeeter918
Tulsa, OK
Load x RPM x .00471
so not too far off, right at 370 with drivetrain loss.
bmytych
