What's your STFT+LTFT at that point?On my 391/470 dyno run, I pulled up my data log.
Ambient Air Temp: 78 degrees
Fuel: 91 octane mixed with Torco T85 for E30
Load x RPM x .00471
1.62 x 6293 x .00471 = 48.01
Load x RPM x .00471
Average them dont just add together![]()
Yeah sorry wasn't very specific was I? Yes add them, then subtract 2, multiply by 100 and that's your % error. So your airflow figure should be pretty accurate. Multiply by .97 and that should be REALLY CLOSE to reality. ~46.5 lb/min actual flow.Just following directions. STFT peaked at 1.01 but stayed in the .94 range most of the pull. LTFT held at 1.05 for the pull.
.94 + 1.05 = 1.99
FTIW, this was tune was a revision, loaded while on the dyno, and full pulled.
The thing to understand is that ultimately all it is doing is looking at rpm over time and applying some calculus. With automatic transmissions the huge torque spikes at the beginning are normal due to RPM climbing rapidly until the torque converter reaches stall speed. Not accurate, but normal.OK, tried to revisit this and got rid of the junk before 2k rpm and all runs where in 3rd gear.
All else is identical but I just can't put much faith in how accurate these are. All my charts always have a dip in the mid-range and wondering if that's a result of the tuning or I'm data logging incorrectly.
First run/tune on e85. Was the first tune and intended to be somewhat "light/easy":
Next revision. As I wasn't getting pure e85 from the pump, Brad decided to do an "e75" tune to allow for some crap at various pumps. This is the tune where it was discovered the low pressure fuel couldn't keep up:
After the BAP installation and no tune revision:
Run 01 after a tune revision (and this is where it starts going off the rails):
Run 02...jeeez..no WAY this is even close to accurate...
It's so wild, I don't even feel like I can use it as a tool to identify improvements...
That dip I get in all my tunes around the 3500 to 4000 rpm range...is that normal? Most dyno charts I'm used to seeing have a general consistant climb and drop off...
Wondering if I should smooth all the way to 6.
IDK what to make of all this...LOL...but 902ft-lbs sounds pretty bad ass in my book, haha
Yes, I have a street in Mexico that I do all my data logging....hmmmm.Did you do all this on the same road? The roughness of the road translates into the graph.
Interesting...it's a pretty flat road but I think has a very gradual down then up...how significant does that dip have to be for it to effect the data?
I questioned it as well but this is what my buddy who is a Ford engineer gave me. Confirmed by a few other places online.
Load x RPM x .00471
