Virtual Dyno Day!
FiveLeeter918
Ortiz Performance Sales
Tulsa, OK
Hey guys, so I wanted to start something new here. We've talked about it on our Facebook page and on other platforms, but we are a big proponent on the Virtual Dyno program for converting datalogs into dynographs. With clean data and correct correction factors, we've found the data to be pretty accurate. We've tested the program against our own Dynacom 5000 Series 2WD dyno on several customer cars and it's always been within 3% of our actual numbers. You can use SCT or HPTuners datalogs, you can even use Torque PRO on
Android if you aren't currently tuned but have an ELM327 bluetooth dongle.
Download Virtual Dyno here:
http://www.virtualdyno.net/
After playing around with the settings, this is what I think everyone should use to keep things stable. The Taurus SHO is not part of the database, so you will need to create a custom profile. I've attached my file below, but you can also create your own using these specifications:
Vehicle tech specs:
Flex/SHO/Explorer Sport transmissions ratios
1 4.481:1
2 2.87:1
3 1.84:1
4 1.41:1
5 1:1
6 .74:1
R 2.88:1
non-PP
Final Drive 2.77:1
SHO PP
Final Drive 3.16:1
Weight options:
SHO weight 4224
Flex weight 4781
Frontal Area:
Flex 25sq ft
SHO 28.95 sq ft
Drag Coefficient
Flex .355
SHO .36
Virtual Dyno facebook page:
https://www.facebook.com/VirtualDyno
Another how to on Virtual Dyno:
http://forums.evolutionm.net/evo-dyno-tuning-results/619146-how-use-virtual-dyno-properly.html
So how do you stack up?
  • SHO.zip
4sfed
Vehicle tech specs:
1 4.481:1
2 2.87:1
3 1.84:1
4 1.41:1
5 1:1
6 .74:1
R 2.88:1
non-PP
Final Drive 2.77:1
SHO PP
Final Drive 3.16:1
Weight options:
SHO weight 4224
Flex weight 4781
Frontal Area:
Flex 25sq ft
SHO 28.95 sq ft
Drag Coefficient
Flex .355
SHO .36
Oh I can't wait to try this! Thank you!
Wait, the SHO has more frontal area and less drag coefficient than the flex!?!?
Sent from my Pixel 4 XL using Tapatalk
Looks like fun. I guess I will have to pull the ole bull out of slumber.
FiveLeeter918
Tulsa, OK
I questioned it as well but this is what my buddy who is a Ford engineer gave me. Confirmed by a few other places online.
High on Ethanol
Just Ain't Care
USA
Thats crazy! The f150 is like 0.40 I think....i can't remember where I saw that number
High on Ethanol
Just Ain't Care
USA
Is that with the tailgate down?
Well i didn't want to tell you this before your wife did.....but...the f150 has wind curtains.
Also has a tailgate spoiler thats more aerodynamic than the SHO version.
But....im sure ford knew Noone would hotrod a rental.
802SHO
Boost > VE, MBT, Cams
Essex Junction Vermont
Vehicle tech specs:
1 4.481:1
2 2.87:1
3 1.84:1
4 1.41:1
5 1:1
6 .74:1
R 2.88:1
non-PP
Final Drive 2.77:1
SHO PP
Final Drive 3.16:1
Weight options:
SHO weight 4224
Flex weight 4781
Frontal Area:
Flex 25sq ft
SHO 28.95 sq ft
Drag Coefficient
Flex .355
SHO .36
So I can take my fastest quarter mile time datalog and just enter it and it'll spit out a graph?
FiveLeeter918
Tulsa, OK
huh, says needs throttle position...its a missing column needed for calculation??
For some reason you get this the first time. Forgot about that. Open your log in Excel, go to Throttle Position and copy the header ID text. Go into the options/settings in Virtual Dyno and paste this for the TP index.
802SHO
Virtual Dyno Rev26 meth 3rd gear pull
This was a 3rd gear pull AJP Turbo 20 psi this year. Weight of the car I guessed at 4200 with rear seats out and myself and an occupant, he must weigh about 165 plus me at 205. I'll need to do another one. Whenever I get the damn passenger hub squared away. I dunno why air/fuel isn't on the graph.
ridered74
Did you have to create a vehicle profile to get it to work? If I load a run it's just blank. If I try to create a vehicle profile it puts a flashing exclamation point next to final drive whether I put 2.77:1 or 3.16:1
