valve stem seals
sho4life
midwest
Does seafoam ruin them? It says there are three ways to use it. In the oil, gas tank and intank. I know if you use it in the oil you should get an oil change not too much longer afterwards.
I had an old engine that sat for awhile and high mileage oil seemed to help but just dont want to make it any worse
lowc
aka vapah lock
Quincy, massachusettes
im sure if it ruined them they would not tell you to put in oil. ive ran it in my oil a few times and has been in there for almost the whole 3k and havent had any issues
itwonder
VA
Seafoam won't hurt. High Mileage conventional oil will help. Stay away from synthetics if valve stem seals are leaking.
91PDXmocha
Portland , Oregon
Castrol GTX high mileage . few oil changes with it did better on oil consumption that any additive honestly. Ran a 150k motor that was black as shit when I got it. 3 oil changes later with castrol when I did the valve cover gaskets could already see the HUGE difference it made .
firebat45
Edmonton
They tell you to change the oil for two reasons, because SeaFoam doesn't really work as an oil additive, it's a cleanser, and because it gets a bunch of crud off the motor and into the oil. It's like changing dirty dish water.
thatSHOguy101
