Anybody know what this part is called? Some sort of vacuum line check valve. Seems as if I have a vacuum leak but no leak has been found, I think I have dialed it down to this piece, it is whistling quite loudly as if the check valve is stuck, sprayed a little Wd40 inside with no luck.
