Two SHOs...Multiple issues...Need insight.
Speedie13
That's Decent!
Lincoln, Nebraska
My two wonderful SHO machines are having quite a time lately and Im pretty much at a stand still as far as diagnosis. I will start with my 95 MTX. I have a hellacious belt screech/squeal when I start it up and also when engaging/running the A/C. I replaced the front (towards headlights) belt tensioner, after my other one fell apart on me, because it was also making the belt squeal...atleast I thought it was the problem at the time. Now Im wondering if the A/C condsensor is going bad since the belt will squeal when its on, plus if I turn on Max A/C my motor and tach go crazy (almost dying, really low idle, oil light, etc.) Any ideas on what I can try to figure it out?
That is issue number 1. Number 2 is an intermittant problem dealing with fuel I think. When under acceleration (mild, moderate or otherwise :evilgrin: ) I occassionally get a kick or stumble. It feels like I just lose power all of a sudden but then it kicks back in, sometimes rather violently. Im replacing the fuel filter tonight, though (as you will read) I dont think it will solve the issue.
Btw: Checked codes and other than the ever-present 551 issue everything came up A-Ok.
EDIT: I went outside and ran the 95, usual belt squeal at start up, then I turned on the A/C and listened to the belt. There is a ticking noise with the A/C on that is either coming from the (newly installed, refurbished) Alternator or the A/C Condensor, but I couldnt figure out which one.
So thats the 95, anyone confused yet?
The 93 3.2L MTX is also having a very similar fuel (i think) issue, though I have codes for this one. They arent the exact same issue because the 93's is a much more strung out event. The car will surge/buck under mild acceleration and chug at idle. I can drive it while this is happening but not very fast or very far, though it usually only lasts 5 minutes or so and then the idle smooths out and its fine again for a week or so. Here are the codes I got...
KOEO
111
Stored Memory
113 - IAT (high or Open)
214 - Error in CID sensor
556 - Fuel Pump primary circuit fault
KOER
116 - ECT out of range
225 - Knock Sensor not tested.
I know the KOER codes are probably there because the car wasnt warmed up. (I got the same codes from my 95 on a "cold" pull of the codes.)
I have replaced the schrader valve and fuel filter on the 93 recently due to leaks and what not but otherwise nothing has been done to it lately.
I hope this makes some sense to someone as Im in need of some advice and info. I have been throwing around the idea of getting rid of them both because I dont have the money or patience to keep them both up but if I can get a little more insight into their issues I might not feel so bad about spending the money or time on them. As of right now they are my only transportation and when they act up I just wonder how long until they strand me somewhere.
Anyway, any input is greatly appreciated, TIA.
trevor404
Addicted
Alberta, Canada
My car just started squealing like your '95 did. It was also accompanied by sparks coming out of the a/c pulley. It sounds as if your a/c pulley is ceased and the belts are slipping and screeching. The low idle and erratic tach when the a/c is on could be because the belts are trying to turn the a/c pulley but can't so it is trying to stall your belts and, in turn, stall your motor. I just bought my new a/c pulley from NAPA (in Canada) for $120. Just my opinion. As for your other problems... :S
trevor404
Addicted
Alberta, Canada
Get someone to watch your a/c pulley while you engage the a/c to see if it is turning or not. Or take off your belt and spin it by hand . The inside clutch and the outside pulley should both turn freely and not have any slack side to side.
93rev2sev
Hockeytown
Time to clean your MAF sensors and bypass the A/C...or replace the A/C compressors and at least the suction and pressure lines.
