roswell998
93atx 112K miles
Suggestions please! The following details everything I've recently done which has a couple of thousand successful miles experience.
1. Turns over fine but won't fire.
2. No KOEO codes...nothing but 1's on both self test and stored codes.
3. Previously every week or so it might take a couple of trys to start but then it ran fine. As a result of this intermittent starting problem I checked fuel pressure a few weeks ago and it was about 41psi. I haven't checked pressure today but will tomorrow. The pump was replaced a few months ago, has worked fine and I can hear it whining for a few seconds when the key is first turned on so I expect fuel pressure to be ok but will post test results tomorrow. Also, the fuel pump relay was replaced and I know it is working fine.
4. As signature shows, both upper and front 60k's and most preventative maintenance has been done in the past few thousand miles such as; new 155 lph Walbro fuel pump, valve adjust and new cam cover/sparkplug well gaskets (no oil in wells), new AGSP32FM sparkplugs and Delco wires, new Camshaft position sensor, new timing belt, nostrils cleaned, new DPFE sensor, new throttle position sensor set to just under 1 volt.
5. Original ignition module and CPS, however, the tach has not been erratic.
Thanks
Thanks
