Tune up
lunchbox0029
Fort Worth
I did a tune up on my 95 ATX I did Intake,Valve cover,and throttle body gasket.I did the wires and plugs. And I wanted to know if you guys thought if I should do the O2 sensors I have already bought them or should I save them for later.I didn't change the timing belt because it was changed at 93,000 now it has 122,000 I will be doing more work at the first of the new year I'll do it then. :wave:
LOUDSHO92
Sponsoring Vendor
Rancho Cucamonga, CA
If you have them replace them. You really didnt need to do the intake or throttle body gaskets. Make sure you get you get your valves adjusted though.
NiNeTy Fo SHO
No-mo-SHO Man
Troy, Ohio
lunchbox0029 said:
you got to take it off
Not necessarily....but probably makes it easier. I did all 6 plugs and wires without removing the intake nor the supports for it. (I did unclip the black canister on the back of the intake though.) This was when I first got it and didnt know exactly what it took to get the intake off. I was very flexible and good at finding the hole without looking. (plug hole.... :naughty: ) Now I am older and not as flexible.
