TRUNK LOCK
SHOWHAT9
WHEATON, IL
We tried this experiment last month at the Peoria camweld and the results were amazing. How many people on this forum can open their trunk with the Key??
No, I'm not gonna sue Ford over this one. It was just a complete surprise. I thought I was the only one. Try it. eek!
99V8SHO
GasOilAndTires
Gaithersburg, Maryland
Come to think of it...I have never opened my trunk with my key. Without the key there are still 3 other ways to open it. I either use the remote, or if my key is not with me, I open the door and hit the trunk button, or i use the combination on the keypad. I have never actually had to use the key to open the trunk.
<small>[ June 27, 2003, 04:53 PM: Message edited by: 99V8SHO ]</small>
stephen newberg
Ladysmith, BC, Canada
Well, you certainly got me curious, so I just went out and tried, and sure enough, it does not open with the key, but considering the car is 5 years old and I do not think I have ever tried to actually use the key before, it could easily be that the lock is just frozen. Not many turning parts still will turn after that long a period of never having been moved or lubricated. I do on occasion open the driver door with the key, but I also lub it once or twice a year. Same for the fromt passenger door. Bt I do not remember if I have ever done anything with the trunk lock.
pax, smn
E1
Crash Tested
Chicago area
I'm batting .500
My 36,000 mile garage queen key works fine.
My 122,000 with spun cam and a SLO trunklid doesn't.
Been monitoring this question After the first round of this issue on V8SHO.com. Seems to be about 50/50 on the cars I've seen. I managed to get one to work again out of desperation on the Supercharged 97. I moved the battery to the trunk and the battery went dead on me. No power to trunk release and key won't open trunk.HUH. Guess I better make the F%&@#$G trunk key work again!
Glen Cleeton
Massachusetts
Mine does! October '96 build. Sunroof, cloth, chrome wheels.
Cheers
GC
Iv'e not been posting lately because the forum won't let me post from my webbie (some odd javascript thingie)
SHOGHOST
ST. Louis
I tried it again today to show my friend and sure enough it unlocked it this time! thumb
SHOWHAT9
WHEATON, IL
99V8SHO:
And the plan when the battery fails would be???Not that there is anything all that important located in our trunks, I agree with Steve, it's probably simply lack of use. Mine is a 97 with Factory trunk - and no after a can of SHO **** (WD40) still won't work - ARGHGHHHH
nothingtoseehere
SHOWHAT9:
99V8SHO:
Plan when the battery fails? Thats easy. Use yuor key to get in the car and climb in through the backseat to the trunk :D
Funmart6
my name is mud
Auburn, Alabama
Mine doesn't work either, just tried it after reading all this. The key goes in but will not turn. cuss
stephen newberg
"after a can of SHO **** (WD40) still won't work - ARGHGHHHH
Just went out and tried mine again after the Liquid Wrench treatment the other day. No go for me either. So it is totally toasted from lack of use or it never worked in the first place, but I do not know which.
pax, smn
E1
Crash Tested
Chicago area
RCADDELL
[/qb]
Plan when the battery fails? Thats easy. Use yuor key to get in the car and climb in through the backseat to the trunk :D [/QB][/QUOTE]
Might work for some, but honestly, Have you seen the SIZE of some of our fellow SHO owners? I can see the headlines now....
"Obese car owners die from heat exhaustion after getting stuck climbing into trunk from backseat. What were all these people trying to do this for?"
Might be a better angle to sue Ford from, More life threatening than Camfailures. LOL.
:rolleyes: :rolleyes:
SHOWHAT9
WHEATON, IL
E1:
:rolleyes: :rolleyes: [/QB][/QUOTE]
Hmmmmmmmmmm........ rant
Mine doesn't work. On my brother's T-bird I recently had to spray some WD40 into the door locks and force the key in brutally. I might try this on my '97 if I get a valet key made. Don't want to break the chipped ones.
Funmart6
my name is mud
Auburn, Alabama
My car came with two remotes and two keys. Both keys have the chip, they both fit the door and ignition and both will start the car. These keys have an "S" stamped on them, what does this mean. Also,they both go into the trunk lock but alas, the lock doesn't turn.
