trouble starting
RGuy
Texas
I just bought my car today and have trouble starting it.
when I try to start the engine, it will turn over and over, but won't crank/run unless I press the gas pedal a little. The prevous owner told me to press the gas pedal before trying to start the engine. Is this normal?
Thanks.
Rob
wood_e
The dude
Ames, IA
thats never normal. I believe your cam position sensor might be shot... but I'm definitley no expert. Have you checked your codes?
RGuy
Texas
the check engine light comes on intermitently but I haven't had a chance to check it yet. The previous owner had CPS replaced the first of the year with the 100k maintenance.
Rob
wood_e
The dude
Ames, IA
Sometimes the cam position and the crank position sensors get confused. Maybe the crank weas replaced and not the cam? Anyway... check the codes and see what you get....
masho95
got Zex?
Chicopee, MA
If you are talking about the camshaft position sensor (CMP) then how many miles ago was it replaced? I just had my CMP fail in only 30K miles. The orignal Ford one lasted until 60K and I replaced it with another Ford unit. This time at a little over 90K miles I replaced it with the Autozone equivalent, and I'll have to see how long this one lasts. I had no drivability issues with the recent CMP failure other than a intermittant CE light and very occasional hard starts (hard to press the gas to start the car). But I don't know if the hard starts are in any way related to the 214 code the computer was throwing.
RGuy
Texas
I pulled the codes today and got 12 (idle speed) and 72 (no MAP/MAF).
can you help with this?
Thanks.
Rob
wood_e
The dude
Ames, IA
Make sure your MAF sensor properly connected. Try reseting your idle speed. You should find instructions if you do a search.
Ignore all the above. While well-intentioned, it is all incorrect. Your Idle Air Bypass (IAB) valve is not working.
By having to crack the throttle partially while starting, you are performing the task that the computer is expecting the IAB valve to perform. BTW, this procedure is suggested in the Owner's manual.
Your receipt of the code 12 is verification that the IAB is not functional when the computer expected it to be. You can attept a cleaning of the valve to see if that fixes the problem, but be prepared to spend the $55-60 at AutoZone for a replacement. Note: This part is also referred as the Idle Speed Control/Bypass Air (ISC/BPA) or the Throttle Bypass valve.
As for the 72 code, it may be due to a diry MAF sensor or might have been caused by an insufficent throttle application during the "goose test".
RGuy
Texas
Thanks Steve.
If the IAB is the unit mounted behind the TB and has/had 2 coolant lines going to it, the previous owner replaced it in Jan. 03 when the 100k maintenace was performed. I guess I could take it off and make sure it's clean anyway.
Rob
RGuy
Texas
I was driving today and it seems that the "check engine" light comes on when I let off the gas pedal for the most part.
I assume the hard starting and the CE light is related.
any thoughts???
Rob
AutoSHO
No SHO = Mo $$$
Fort Collins, CO
Sounds like your MAF sensor is dirty. It isnt sending a strong enough signal to the computer, and it trips a code. Just my guess.
Mr Anonymous
Tire Wall
RGuy:
any thoughts???
Rob
You have your answer above. Replace the IAC/IAB valve. Cleaning it isn't likely to work at this point if it's throwing a code. Sometimes even relatively new parts fail. Replace the IAC, clear the codes, and that should solve your starting problem. If you continue to get a CEL for the 72 code, then you'll need to address that, but lets take it one step at a time.
RGuy
Texas
I took the IAB off this weekend to clean it but it looked fine. In fact, it looked brand new.
I tried to test the unit by putting power to it in order to make sure the little plunger/piston thingy was operating. I could hear what sounded like the little motor operating, but the plunger/piston didn't move.
Is it possible to test the IAB? If so, should I see the plunger/piston moving?
By the way, the codes were 172 and 214, not what I stated earlier. ...my mistake.
Lately, it seems harder to crank even while cracking the TB open a little.
Rob
JoeHoe_SHO
SHOPUKE
Rochester NY
Yeah...check your MAF connections.
Would a really dirty air filter do this?
Not sure at all, just trying to help :confused: shrug
Mr Anonymous
Tire Wall
RGuy:
Rob
You just tested it. Now you can feel better about replacing it. Sounds like you also need a CID sensor. About $30 for the Wells F134 at AutoZone.
RGuy
Texas
I replaced the IAB and the problem is still there. It's not as bad as before, but it's still there.
Not to long ago, I checked the codes and got #214 with the engine off, not not with engine running. After clearing the codes, it hasn't shown back up. Would code #214, have something to do with difficulty starting?
Aside from the difficulty starting, it runs great.
Rob
masho95
got Zex?
Chicopee, MA
The 214 code is for the CMP sensor and definitely would cause hard starting problems. Try replacing the CMP sensor and you should be all set.
