NotSoSlowSHO
Gas is $$ WALK!
this belt is giving me a heck of a workout. Im to the point where I can dissasemble the front of the motor blindfolded squint
I have tried tensioning the belt 3 times now. And the belt is still "wandering" and working itself off the cam gears squint
Help! Did I missread something?? What am I doing wrong?
The car is running excellent, so I know that I have timing correct.
Tensioning:
Crank it over a couple of times, then possition the crank @ 60 degrees before TDC. Then loosen nut on tensioner...
This is where I think Im screwing up. How much tension to I apply to the tensioner? Or do I just let the tensioner apply tension?
I tried just letting the tensioner do it's thing without any additional tension.
Then I tried adding a bit, same results.
SO I tried addiong a bit more...
And NOW I have nearly detroyed my middle timing cover because the belt ate a groove in it cuss
Somebody please shed some light...
Tensioning:
