Time to put up or shut up.
zach44102
BIG TURBO
Georgia
Its time to dew work. Next friday. Going down to Silver Dollar Raceway in the blue car in hopes of breaking not only into the 13's but breaking the all motor record. Its been a **** of a build/journey over the winter to get the car together and now its time to find out of all the work was worth it.
A little bit of info on the car and previous runs:
1995 MTX
Weight: 2780#
Motor: 3.2 swap, BBB, Pnp runners, gasket matched, Underdrive pullies, SHOshop stage 2 cams, stock heads, Fenderwell intake, SHOsource catless y pipe.....dumped.
The cars current best was 14.2@100mph. That was with stock cams and 200 pounds heavier with a gen 2 subframe. The car now has a gen3 subframe.
The car is getting trailered 2 hours away to Silver Dollar because of the 600 feet of elavation difference than Atlanta Dragway which is only a hour away.
Wish me luck.
BlackonBlack89
burlington county,NJ
Good luck! I hope u do it. **** i hope u run mid 13s.
Wat tires and wat clutch? Stiffen the rear up with some spring blocks. And the weather will either help you or fight you. Hopefully it will be nice when u go.
zach44102
BIG TURBO
Georgia
Here is the kicker doing it all on street tires. Bridgestone Potenza RE760's. These tires are great though! consistent 2.2 60ft's with them previously. I have a Southbend Stage II clutch with A LOT of passes on it. The great thing about Silver Dollar is they do night races. Temps should be around 70 with 60-70% humidity. IIRC Silver Dollar is 300 ft ABS
BlackonBlack89
I have the ultimate wheel/tire setup to bad ur so far away. I wanna see someone break this record like I wanted too. then I got hp greedy with boost. that and my clutch hated the QTP's :)
Its all in the launch, ull need a perfect run to make it happen. Ill be looking forwards to seeing the results! :thumb:
zach44102
BIG TURBO
Georgia
I know I have a LOT of stiff all motor competition this year. You with the getted cammed 92, Marcels cammed HC 3.3, Tim Tyners gutted 250+whp track car and a few others.
zach44102
BIG TURBO
Georgia
Last time i dumped the exhaust i picked up 2mph in my trap speed as well as .2 off my E.T.
whiteguy3
Scott MacIntire
Silver Spring, MD
Cable mod and subframe will be the bigest help. Dont use spring blocks...Just do the cable mod.
Sometimes I wish I didn't let go of my ATX. Would have been in this record breaking talk...
somedude_001
Western NY
my turbo ATX NEVER had wheel hop. I wrapped the steel cable around the engine mount so it would tension against that under power. It was a beast.
One day I will mod another ATX and run low 12's with a stock trans... Best of luck to you!!! That is a crazy light car you have there!
zach44102
BIG TURBO
Georgia
You are supposed to cable the rear end. What did you do?
nc89sho
S13 Sellout
Clemmons NC
yeah.. don't think i'll be trying that anytime soon. but i will be headed to the strip soon.. now with more power:dribble:
93rev2sev
Hockeytown
yeah, there's going to be a lot of movement at the tops of the lists this year.
