Throttle hesitation and idling problem
Washington
Okay so i got a code 114 with my 93 mtx. i cleaned my iat sensor and it still hesitates and as the rpm drop it tries dying then rpm jump up then down then up then levels off and idles at 800 till i blip the throttle and does it all over again...what do i do??
intimdatr
Got Cams?
Jefferson City, Missouri
Have you done any work to the car recently? Sounds like you have a vacuum leak.
If you havent done anything recently that would cause the leak it maybe time for a new IAC or a good cleaning of the MAF.
Irish Pride
Irish Inside
MusicCityUSA
Try to reset the idle. Search for "idle reset" and follow the procedure exactly how its laid out.
