tape deck powers up but no sound
Sho Amo
SmkTyresntDrugs
Olney, Md
My tape player works but i get no sound. My antenna goes up when i turn it on also. Help please
Sorry for the wrong section, just noticed
NiNeTy Fo SHO
No-mo-SHO Man
Troy, Ohio
You may want to check the following:
1) The amp in the trunk..make sure a connector is plugged into each side.
2) The connectors are plugged into the back of the radio. (There is a power connector, a speaker connector, the antenna, and the wire clip for the buttons by the steering wheel. There is also a cd player connector if you have a factory cd player.)
Check those..and report back.. :)
shoteen95
isn't a teen :D
Dearborn Heights, MI
do you get any sort of hissing or audible pops when adjusting volume, treb, bass, etc. If so, you're headunit may have checked out. Both of the stockers in my 95 and my dads 93 went bad.
Or is this a problem with the tape player only (radio working fine)?
Sho Amo
SmkTyresntDrugs
Olney, Md
no nothing works it just powers up and i get no sound, but the antenna goes up when i turn it on.
SASHO91
Zoom Zoom
San Antonio,TX
Do you have brake lights???
check the Fuse(big 40a IIRC) in the engine bay. cant recall what place it is, but it says its location on the back of the cover though.
I had that on mine...
just another place to check.
Sho Amo
SmkTyresntDrugs
Olney, Md
No actually i dont have any brakelights but i checked the fuses before and im pretty sure they were all good. I checked them with a test light and a visual test. I noticed that one connector is out of the amp. Its on the left side and i dont know where the connector is, i didnt have much time to look it was getting late and dark.
Sho Amo
SmkTyresntDrugs
Olney, Md
I checked today and there are two connectors going into the amp. I was looking at the wrong thing before. The amp is black not silver right? I checked all the fuses and theyr good. I have no idea:banghd:
dantheman68
Kinda Big deal
Pewaukee, Wisconsin
is your battery old or with a low charge? it sounds simple, but my car ran with a bad battery but the radio didnt work, i also had a bad alternator...
Sho Amo
SmkTyresntDrugs
Olney, Md
yeah it kinda is ill try that eventually. I doubt it is the problem tho.
Sho Amo
SmkTyresntDrugs
Olney, Md
etc1006
Baltimore, Md.
Man, you still buggin with the tunes? At this rate I'll be back there and be able to give you a hand! J/K:nut: Definetly charge the battery though!
