Tachometer question
ManicMike
Speed Freak
Bear, DE
Well, ever since i've had my '92 the tach was slow. Like, it wasn't in time with the motor. Like if i bliped the throttle, it would barely move. But then if i was ringing out the gears, it was perfect. I know i don't need it, since i only need it when i WOT, plus you can also hear the motor when its near red line. But for the fact of having it and when my mother drives the car..lol I would like it to be fully operational all the time.
I have a short video to explain my problem more:
http://www.ifilm.com/ifilmdetail/2700946
Any help is would be great.
-Mike
ManicMike
Speed Freak
Bear, DE
cougarman said:
Yep, looks like the needle is hanging up on the overlay. ;)
Thanks guys, yea. I was wondering that. I did remove the EATC a while back, i guess i should fool around with it more.
What should i do like? To help it not bind up?
LeddZepp8687
The Keg Rider
Naperville, IL
Lots of double sided tape?? I couldnt view the movie that you made, but I am assuming that you have white faced gauges?? Cause I have WFGs and i only used only a little bit of double sided on the back or the fuel gauge and coolant temp gage overlay and it was hanging up on my gas needle. :doh:
ManicMike
Speed Freak
Bear, DE
Ok, i don't think its the DST, because they where wroking fine untill i removed the dash to get the EATC out. :) :confused: :bonk:
Gez89SHO
LEGO SHO
NE Philadelphia, PA
The dash removal may have disturbed the backing. Are the tach/speedo/fuel &temp parts separate or is it all one piece?
I would open it up and move the tach by hand to see where it binds, then adjust the backing as needed. It might even need to be removed and trimmed around the needle opening a tiny bit.
Edit: be aware you'll be working near the aribag so be careful.
