Tach cuts out????
krednjen
Kit car/90 SHO Derek SA TX
San Antonio TX
Wired in a Sunpro tach (homebuilt car/never had a tach before), and it cuts out at 4k, every time. Josh (SASHO91) said his stock tach used to do the same. Any suggestions.:confused:
AREA 91
PA SHO SHOP
Area 91
I believe the tach signal is the top wire on the "fire wall" side of the DIS.
Slo-Sho
It wasn't me!
Crossroads, CNY
Actually, you can use the Gray/Orange wire on the DIS module. Also the aftermarket tach will have to be most likely set to the 4 cyl mode.
crystizel
