subframe problem
Dr_Thompson
CT
im putting my subframe back up and i cant get the front bushings to allign properly. the back ones are fine but the fronts are off by a quater inch. I thread the bolts in and bout 3 quaters of the way the bolt wont move anymore. Im not sure what the problem is. Im using cup style ASB's. Any comments/suggestions?thanks
masho95
got Zex?
Chicopee, MA
Make sure that the rears aren't completely tightened up when you try to get the front bolts in. Start the rears and get them maybe 1/4 - 1/2 way in and try to line up the front ones and start threading them. When you get them 3/4 of the way threaded does the bolt stop threading or just it just spin?
Dr_Thompson
CT
masho95, right after i posted this i went out and loosened the rears and then the fronts slid in. :D
Cobraii976
I am an idiot
Now go back out and loosen them up and grab a pair of tire irons. and get them in the alingment holes in the back of the front bushings. Get it as close as possible before it goes on the rack.
