street night at ne dragway
cohill87
92mtx redonblk
boston/western ma
ran my 92 for the first time, first time with a fwd manual, I did horrible, first run I rolled out with a
rt/of .356 60ft 2.753 1/8 10.669 1/4 16.230 at 89.94
second run founf out i need strut rods bad!! launched it this time with horrible wheel hop and every thing banging around
rt .336 60ft 2.652 1/8 10.428 1/4 15.894 at 91.35 finishing with my steering being like 60dregrees out
Third and final rolled it out rt
.341 60ft 2.504 1/8 10.287 1/4 15.809 at 90.43
car has magnaflow y pipe ss intake dynomax cb and toks with eibacs
cohill87
92mtx redonblk
boston/western ma
*strut rod bushings and repair kit, I also had a passenger, spare tire and a bunch of tools in the trunk probably would'nt make much of a difference, maybe a tenth or so
cohill87
92mtx redonblk
boston/western ma
Screw thr r/t, fix the 60'. You are a half-second off where you could be.
I know I didn't want to launch the car, I need to fix the subframe issues, I didn't realize how bad the issue was until I tried to launch it that night. So I just rolled off the line.
RonPorter
SHO Club of America
Lake Orion, MI
Doesn't indicate much. With a very crappy 60' and 1/8-mile, the trap speed isn't too far out of the ballpark.
cohill87
92mtx redonblk
boston/western ma
what should a 60ft be for car with these mods? Also would an lpm help me out that much with just an intake and exhaust?
RonPorter
SHO Club of America
Lake Orion, MI
If the car is basically stock, keep shifts no higher than 7K.
Regardless of mods, a 60' of 2.2 - 2.3 is very good, 2.1 if you catch it right.
SHOspazz92
Banned
Triad Area, North Carolina.
In my Experience....again.. This is Just me...60' Times have never had to much effect on my trap speeds... Maybe half a MPH or so. In some cases, I've had better MPH with Worse 60' Times. In my green car, I had a Fastest Time of 14.1@100 MPH with a 2.2 60'...However... on a later run (With no difference in shift points or cool down time) I blew the 60' Time (2.5) and went 14.5@101.
Same thing with my 95, Fastest run was a 14.7@95 (Stock, Minus a SHOshop Y Pipe) with a 2.2 60' Time. However, My fastest trap was 96 MPH with a 60' of 2.4 that netted me a 15.1
I can't recall my how my White 92 went but I seem to remember the trap speeds being pretty consistant (91-92 MPH @ 3,2000 Feet Elevation, Stock).
does the car not make power above 7?
On stock Cams, No. Shift at 7,000 RPM's and you'll be set.
-Sam
walser
new ulm MN
on my car with mods in sig i got a 2.2 something 60ft and the best E.T. i got was 9.96 in the 1/8th but i kept it in second bounced off the limiter once at 7500 as i got through the traps, a little high for a car with out cams but it was my best time. i think i shifted outta 1st around 7k ... luanching at around 3k doing a hard rollout spun tires just enough to keep her from bogging
SHOspazz92
Banned
You definently should have went in to 3rd gear. You could have netted an Easy 9.5-9.6.
-Sam
RonPorter
SHO Club of America
Lake Orion, MI
-Sam
With a better 60' (since his were so bad), he should be 90-91. Which, for a stock, high-mileage SHO, ain't really too shabby.
Brad kirk
