uchy1991
From a cold start it sounds fine. Idles at 1000 rpm. After about 5 minutes it starts to jump between 400 too 1000 rpms. Sometimes it will stall out. after it warms up a bit it is usually runs fine. I changed out the IAC with a used one that I cleaned up with carb cleaner and it runs the same. Thanks for the help! Josh
