Off Road SHO
Moderator
Ok, I have double checked everything. The plug wires are correct, and all hoses are hoked up the grounds are good and I didn't remove the dis module.
The reason I think the injectors aren't working is that, with the front plugs removed and someone cranking the engine, there isn't any puff of fuel or the smell of fuel comming from the plug holes.
Well then your next step is to see how much pressure is in the fuel rail during the one second that the fuel pump is running when you hit the start key. There is a Schrader type valve on top of the fuel rail, right behind the throttle body. Stick a tire guage on it while your cranking. If you don't see at least 25 pounds of pressure, there is a problem with your fuel pressure regulator; that's the little round diaphram valve at the other end of the fuel rail that has the vacuum hose on it. Let us know what pressures you find.
Tom
