Aqua Roach
Deadly Insane
Hey guys, I'm writing because I'm still having problems with my SHO running.
Recap:
I swapped a 3.2 into a Gen 4 Taurus. Been driving it for almost a year with no problems, not quite like this one.
Recently with the cold it seemed like it wouldn't hold an idle at all. You can start it up, it runs for a second, then dies.
If you give it gas, the revs drop before coming back up a little, then dies.
I have to start the car repeatedly until it finally holds. Strangely enough, when it holds, it has no more problems at all.
Typically the whole time she runs rough it lets out white smoke that smells like gas from the tailpipes, not rotten egg smell.
The only repeated codes it throws is for the EGR circut, the DPFE voltage being out of whack. I took that thing off and it was corroded, its metal, I cleaned it out only as far as I could so I think it's still clogged internally. Either way, I was told that that "shouldn't" effect idle.
Anyway, with that being said, I thought I figured it out to be bad gas. This only started after I put Shell gas in, and to my surprise I put a tank of QT gas in, and Ta Da! She ran like a champ, no problems for a whole week! Be it cold, or rain, she started and ran perfect!
Then I put $10 of Shell in it like an idiot, and now the problems worse than before.
I checked the gas, and there is no water in the tank at all. Can it just be literally BAD gas? It seems to coincidental, but I'm almost tempted to dump the tank and fill with something new.
I checked the fuel pressure and it's holding at 35ish PSI, holds it for five minutes after its off.
Another code that has come up was fuel pump main circuit failure, but, I can clearly hear the pump singing when I turn the key. And that doesn't explain why it runs flawlessly sometimes. Could it be a dying fuel pump? Since it's holding pressure even when it's dying, I don't know if that's the case...
I know it's not the wiring because I traced it back to the pump already.
I've checked all the spark plugs, some were actually black, but I think that's from it missing and running the way it is, I cleaned them all up and regapped them but it's still the same thing.
I've got a video I uploaded to show what it's doing.
http://vid158.photobucket.com/albums/t116/aqua_roach/Car/VID_20150104_164417465_zpsvcfzjpkg.mp4
Sorry it's sideways, I have no idea why because on my pc it was right lol.
I appreciate all the help! Thanks in advanced.
Recap:
